New Member with trouble!
My opinion is a valve-train problem. Possibly from a popped out shim? Just a guess. I do not think riding the bike for 100 miles would have any negative impact on your bike, unless of course you were riding it at full throttle. Next thing is, I would not even ride it to the dealer, but truck or trailer it there. Don't run it until they repair it under warranty.
Not being able to hear it myself, I think it may be just the cam chain slapping around in there. The automatic tensioner may be nearing that time where it will take it up another notch. After that it will quiet back down and then the cycle will repeat every few thousand miles. So, IMO, it's just normal noise as the cam chain stretches and the adjuster is nearing a take-up point.
But if I actually heard the noise, I may change that opinion, but that's my guess based on your description. Can you record the sound and post it on youtube or something? That may give us a better idea of what you are talking about.
Brian that was my first thought also. i would take it out and inspect it. there may be some damage to the teeth or possibly the spring is too weak to move the tensioner in another tooth.
I had a similar noise, at the mid RPM range. I fixed it by slowly loosening the two bolts holding the tensioner in until I heard it click one time, and then bolted it back down. Now she is quiet and smooth again. You might try this, but don't let it click more than once. If it does, you may have to take it all the way out, and reset the tensioner, and try again. The two bolts are 8mm, one on either side of the 12mm bolt holding the tensioner spring in. I had to slightly loosen the 12mm bolt to move the washer over out of the way of the right side 8mm bolt. Having not heard the noise you are talking about, I can't guarantee this will work.
Personally I think there is no way this is the cam chain, I have heard that before. This is to in sync with the motor, and sounds to be at the very top of the engine. Also, I think it is way to loud to be the chain. This actually sounds very harsh. I easily hear it over the engine, traffic, and the wind when driving. Also, its much much worse on deceleration while in gear. Also if the chain was that loose to make that much noise it would do it at other RPM's.
One more question:
Do yo guys think its normal for a quite tapping at idle. Sounds just like someone tapping on metal with a hammer lightly. It has done this for over 1000 miles.
One more question:
Ok, I just removed the chain tensioner. It moves freely, no burs. I bolted the two 8mm bolts back with the spring removed. Then put the spring back and tightened its 12mm bolt. I let the bike idle for a minute or so then revved it to 5800 rpms, same thing. The noise was not better or worse. The exhaust got glowing red in no time. I have never rode it at night so don't know if thats normal. Is it?
No that's not cool. My oil is clean as can be after 500 miles. Is it staying full for 800 miles or are you topping it off?
What about the exhaust getting red hot so quick? Come to think of it I have rode it at night two times and I never noticed that. When I cut it off, it was making that tinging sound while cooling off it was so hot.
