New FMF
Old 09-26-2014, 12:02 AM
oside5ka's Avatar
Default New FMF
Just got my Powercore 4 and installed it love it. Nice and loud but is it normal for it to backfire when you slow down?
Old 09-26-2014, 12:39 AM
Yep. No baffling to stop it, just the way it is.
Old 09-26-2014, 04:23 AM
2veedubs's Avatar
You can get some backfire relief by tweeking the fuel screw a bit to richen up the pilot circuit when you close the throttle. You may affect throttle response if you go too far. Good luck.
Old 09-26-2014, 01:44 PM
cmott426's Avatar
Did you re-jet?
Mine backfired ever so slightly on decel.
Old 09-26-2014, 04:35 PM
Brieninsac's Avatar
Aside from the air/fuel mixture screw did you follow the instructions for attaching it to the header. Your suppose to use high temp sealant and let it set for 24-hours before firing it up. An exhaust leak can cause that too.
Old 09-27-2014, 04:00 PM
zl PINHEAD lz's Avatar
Mine can backfire pretty loud on decel, especially on a cold start.
I does sound good though
Old 09-27-2014, 06:08 PM
daren1093251's Avatar
Just giving you a heads up on the Powercore 4 it WILL melt your airbox (Happened to me) so what I did is around where you join it into the header I put some exhaust tape to keep the heat inside of tailpipe. Just a friendly suggestion!
Old 09-28-2014, 09:54 AM
That really happened to you?
I have had the powercore 4 on the klx for over 12 months and had no such issue or even heard of that issue.
Old 09-28-2014, 01:43 PM
Really? Might of just got unlucky or something. The side of the airbox that is closest to the tail pipe near the joint is all melted up, not a huge hole but it's still a hole. I've had mine for, 10,000 KM (6000 miles?) with the Megabomb header. I'd post a picture but I can't seem to upload it.
Old 09-28-2014, 07:44 PM
That's odd, I've done around 4-5k miles and no signs of melting of the air box.
Did you bend the rear right foot peg mount outwards for a better exhaust fitting?
Then again I haven't added any head pipe I'm still using the stock header, maybe that's what has caused the melting...
Quick Reply: New FMF
