NEVER SEEN BEFORE ON A DIRT BIKE
Hey Again Fellow Riders. I Have Always Put Neons On All My Cars And Trucks And Friends Alike And They Have Always Been Green. Then I Got To Thinking Today My KLX Is Green Wonder If It Would Work... Street Glow 5' El Wire Green, Used 3 Kits. Not Done Yet Gotta Finish The Rest Up Tommrow.[align=center]http://s136.photobucket.com/albums/q...KLX%20250%20S/[/align]If Anyone Likes What Ive Done I Will Be Bringing My Box Of El Wire Lights With Me I Have Around 70-80 Kits Left. Let Me Know What Everyone Thinks About This Mod?
Heres A Sneak Peak
[align=center][/align]
[IMG]local://upfiles/5167/05E634192360496986E342B4B31C83CF.jpg[/IMG]
Heres A Sneak Peak
Hey that's pretty neat, instead of the plastic I'd probably go for more around the frame that's showing. IE in the dark you'd see just the frame, no other outline kinda thing.
looks good... only if you could drive around like that with out getting in trouble... it looks good for visibility. so what happens when you go to take off the plastic rad shrouds?
I have to take it apart later to work it gets grounded to the bottom screw, disconnects from its transfromer threw the top small hole in the plastic. i could prob put a kit behind the plasitc or the frame. I usualy ride around with the neons on my trucks and havent had a problet yet knock on wood. I Figured if they havent fallin off any of mytrucks i beat out in the feild theyshould be fine on the bike.Ive been drivin with green lights for 3-4 years. what cops get pissy about and will prob mess with you if their to bright (LED), they blink or strobe, blue you cant use cause its ment for emergency people unless you have a blue light licnese then you just show them the paper.
wow.... ur lucky, you would get nailed where i live for driving around with any kind of lights besides the normal ones.... cops are dicks here...
Everything is done now. Added another set to the inside of the fairing. Easy on and easy off ground wire gets tightend down by the lower bolt one wire connects to the lights that are easy to get to through the small window in the fairing.
[IMG]local://upfiles/5167/7CA35C414F5B471A8059F464ABAC6540.jpg[/IMG]
the outside neon. used a mr clean cleaning pad to remove the electrical tape that left sticky stuff on the plastic. pic was beforeall that though.
[IMG]local://upfiles/5167/53DCC66DC3254FA0BB11F1BD5BE06D45.jpg[/IMG]
and there hiding of the switch for easy off when cops are nearby just incase play it safe and switch em off ;-) and some baisc wiring and runnin of the wire and protecting it and wont know how it looks till it gets darker out as for me its 80° Outside time to take the bike for a ride.
[IMG]local://upfiles/5167/0E597EAB3DAC4A90BD964FDA42223952.jpg[/IMG]
galen31075
Oct 6, 2006 04:35 AM
turbomofo
Jan 24, 2006 04:01 PM
