Needle Position Question + Other Questions Thrown In
Old Aug 31, 2006 | 08:28 PM
Thunderchild's Avatar
Default RE: Needle Position Question
You'll need to slack off the chain some for the CS sprocket change. I belive the socket size you need for the CS sprocket and the rear axle is a 27mm. If i'm wrong on the size, someone will be along shortly to correct it.
DO you have any pictures of your Moose handguards yet?
Willum
TC
Old Aug 31, 2006 | 08:47 PM
cwgoff's Avatar
TC,
Thanks for the info.
I don't have any pics of my own. Actually, I just ordered them yesterday. I went on the recommendation of EMS_525, though. You can get a good look at the guards and shields in his avatar and in a bigger picture in this thread linked here: https://www.kawasakiforums.com/m_660...1/tm.htm#66160.
They look pretty sweet to me, and it sounds like they are about as tough as they come. I went for the Titanium finish with the lime green (duh!) shields.
Good luck.
Old Aug 31, 2006 | 08:58 PM
ORIGINAL: Marty
Never a problem.
Here it is!
There's 3 pages of very helpful information here. Lots of great pictures and all.
If you have not already purchased the N1TC needle, you might want to try the shimming as set forth in his procedure. It costs about 9¢ for a stainless stell #4 washer at most hardware stores. About .030 is what you need for a shim. Might be worth the attempt.
Besides, if it's not right, all you need to do is remove the seat and tank to access the needle.
Let us know if there's anything else we can do.
On the countershaft sprocket, make sure you flatten out the retention washer. That's the one that has been peened over to keep the nut from being loosened. It comes off lots easier that way. Air impact is very easy to remove it with.
marty, are you saying to get access to the needle you just have to take the tank and seat off? that might be an easy solution for me to try to change the clip position the the 4th.... but im thinking i have to change the main to a 128....
btw cwgoff those moose guards dont fit right on... i had to drill new holes for the mounting on the inside of the bars, no big deal if you want me to i can take more pics of mine....
Old Aug 31, 2006 | 09:05 PM
cwgoff's Avatar
ORIGINAL: EMS_0525
EMS, that would be great. You can either PM me or post them here if you think others might benefit. I don't know if you can attach pics to a PM anyway. I have never tried. Anyway, as much info as possible on the handlebar drilling, etc. would be helpful.
BTW, do you have the standard size or large size shields. I went for the large size for added wind protection since I intend to commute with the bike through the winter. I live in NC, so the winters are not too bad - plus I only have about a 4 mile commute anyway. Plus, as I said earlier, I am stronger/tougher than most men to boot. Actually, I had to promise my wife that I would really, really ride it as a commuter in place of my Ford F150 in order to justify getting the bike at all. I kind of have to ride through the winter or she will see through my little ploy. A small price to pay.
Thanks,
Chris
Old Aug 31, 2006 | 09:18 PM
the guards i got
ok ill take some more detailed pics later, the reason i got the hand guards is because i didnt want to bend a lever again, it fell over one time and bent the brake lever, and to protect my hands while riding... because of the way the stock bars are they had to get mounted a little higher than i wanted, but they serve my purpose.
Old Sep 1, 2006 | 12:14 AM
YYY.GUY's Avatar
ORIGINAL: Marty
Never a problem.
Here it is!
I've done the jetting thing, but I think I'm going to have to adjust my needle, so this is all I was thinking I had to do. (i.e.: seat & tank)
What about for jets, though? I read somewhere that rather than pulling the carb, you could just rotate it in place to access the float chamber ... anyone know if its that easy?
I removed my carb the first time around for the jetting and slide drilling ... I just remember the throttle cable bracket was a b*tch to get off (I didn't remove the cables from it, just undid the screw holding it and there was enough slack afterwards to remove the cables from the carb.) The problem was there's next to no wiggle room in there to rotate/tip/turn the bracket to unhook it from the carb body.
Is there a secret maneuver to unhooking it, or was I just trying to cut too many corners by not undoing the throttle cables, and everyone else removes the cables first?
Mike
Old Sep 1, 2006 | 09:51 AM
MaverickAus's Avatar
27mm is correct
Old Sep 1, 2006 | 01:26 PM
i have taken the throttle cables and that bracket off and loosened up the air hoses and have rotated the carb a few times now, adjusting the air fuel screw, it works ok for that, i have not looked at it enough when rotated to see if you could change the jets while it was rotated. those damn throttle cables are a pain in the ***..
I was talking to a bike mechanic and was telling him everything i have done, and was asking him some questions, one thing he said to do to find the right place for the air/fuel screw is adjust it while its running and the idle will go up then when the idle starts coming back down just from adjusting the air fuel screw, thats where u want it... sounded reasonable, i believe that is how to do it in a carb on a car... big difference. Being that is my first vehicle with a carb on it, yes i know im young, im still new to this whole carb thing.... anyway... does anyone see a way on adjusting the a/f screw while its running? The only way i can adjust it still on the bike is to take th throttle cables off and rotate it, but i dont think the carb will work properly rotated while running... anyone else have any input on this....
Old Sep 2, 2006 | 01:28 AM
YYY.GUY's Avatar
ORIGINAL: EMS_0525
I haven't tried this, but even though its tight in there, a REALLY short screwdriver (like the tiny ones for fixing eyeglasses) might be able to fit between the starting motor and the carb. The A/F screw is kind of small itself, so an eyeglass screwdriver should do the trick. You have to approach it from the left side of the bike, otherwise there's going to be a HOT exhaust pipe in your way!
Mike
Old Sep 2, 2006 | 03:43 AM
Kawi Wawi's Avatar
I ended up buying one of these...
About $86 plus shipping (lightly used) on eBay.
http://www.yamahafz1oa.com/motionpro...erreview.shtml
