Need some backyard engineering help
Old Feb 25, 2009 | 02:19 PM
mandark's Avatar
Default Need some backyard engineering help
As I was examining the lower cases for the `98 YZ I am restoring, I noticed that on the flywheel side, where the electronics exit the ignition cover, the rubber boot is cracked to such an extent that the individual wires are exposed. (no. not the conductors, I see the wire sleeving of the wires)
Because this is usually a vector for water to enter the system and cause problems, I've been trying to think of a way to seal up the boot.
I'd order a replacement boot but, guess what?
They evidently do not make one. You have to buy the entire assembly
Since I do not want to spend another $200+ for the sole purpose of replacing a cracked rubber boot, does anyone have a suggestion on how to fix it without resorting to buying a replacement?
Old Feb 25, 2009 | 02:27 PM
got pics?
Old Feb 25, 2009 | 02:30 PM
novasteve's Avatar
Just use some silicon, Right stuff would work the best
Old Feb 25, 2009 | 03:04 PM
Shoe Goo Seriously, this stuff is awesome. Or you could use some orange RTV silicone from the auto parts store.
You can get it here at the Motorcycle Super Store
LINK>>>> Here
Old Feb 25, 2009 | 03:24 PM
mandark's Avatar
Originally Posted by hoedogg
got pics?
Will post some tonight when I get home
Old Feb 26, 2009 | 01:35 AM
WestOzKLX's Avatar
Clear bathroom silicone will do the job perfectly. Any hardware store.
Old Feb 26, 2009 | 01:52 AM
green242's Avatar
Well, I wouldn't use just ANY silicone.. I'd use High temp Gasket maker (same as silicone basically).. Or med temp.. But that case would get quite hot, especially after driving the bike for a bit.
Old Feb 26, 2009 | 02:06 AM
WestOzKLX's Avatar
The smart answer would be to replace the part with new.
"YZ Works" in Baltimore should be able to help, alternatively try "Speed And Sport" in Bloomsburg, Pennsylvania. Both specialize in Yamahas and can access hard to find OE parts.
As I understand it the case is a dry case (no oil). I doubt it will get hotter than 100oC and bathroom silicone can cope with boiling water quite easily.
Old Feb 26, 2009 | 02:47 AM
green242's Avatar
haha, high temp gasket maker is probably about the same price...
Sorry, couldn't help myself
Old Feb 26, 2009 | 05:46 AM
mandark's Avatar
Sorry I'm so late with the pics.
Was watching my NFL Films DVD about 6-Burgh's SB Win
Here's a shot of the wires where they come out of the case. It's not so much a problem locating a replacement "grommet". It's that that particular grommet is part of another part and you cannot get it separately. It's either buy the entire $200+ piece or fix the grommet.
I think what I'll do is grab a twist-on soda bottle lid and drill a hole in it the same size as the wires that come out. Then I'll cut it so that I can slip it around the wires and slide it down against the case. Then I'll fill that with silicone sealant. That should be large enough to totally encase the exposed area and cover up the grommet.
