Need to replace my throttle ASAP, please recommend
Old Mar 9, 2008 | 11:01 PM
marc11's Avatar
Default Need to replace my throttle ASAP, please recommend
My throttle is jammed for some odd reason, I can hear the cables binding inside. The screws are stripped (damn soft metal) and no amount of EZ Out will get them out. I have an Enduro this Saturday so I am running out of time. I am going to beat the throttle off or cut the bars and replace them. Who makes a throttle, quick turn or anything that will fit and uses stock cables that I can order Monday for overnight shipping?
Old Mar 10, 2008 | 12:13 AM
Default RE: Need to replace my throttle ASAP, please recommend
vortex makes one.
Old Mar 10, 2008 | 01:01 AM
2k1w=no$'s Avatar
Yeah quite a few are running the motion pro vortex 1/4 turn throttle.
Old Mar 10, 2008 | 01:21 AM
2k1w=no$'s Avatar
I forgot to say that you can use the stock pull cable with the vortex, but you have to ditch the push cable.
Old Mar 10, 2008 | 01:38 AM
KLXer's Avatar
Vortex again. Quick turn makes all the difference.
Old Mar 10, 2008 | 02:27 AM
gline24's Avatar
whats up marc11 i went with the 1/4 turn from motionpro.com part#01-0054. sweet it is.
Old Mar 10, 2008 | 03:15 PM
marc11's Avatar
Thanks everyone. I was able to get the @%$ $^%^7 @#%43 soft as poop metal screws out late last night and fix my throttle. I am now on a mission to replace every single screw with a stainless hex head.
I honstely do not know what type of metal they use of this screws, but they are way over torqued for how the metal just strips out, that are like single use screws, get them out once if you are lucky, don't you dare put them back in.
Old Mar 10, 2008 | 04:18 PM
bryantjt's Avatar
Tell me about it, and Phillips heads on overtorqued screws is just asking for trouble! Part of it is the way the throttle assembly clamps down, if you tighten the top screw then the bottom, it way overloads the top one because the clamp wants to pivot. If you just barely snug the top and tighten the bottom, then check the top, all will be well.
kawi7
Dec 29, 2008 10:12 PM
buckhorn
Nov 13, 2008 06:14 PM
osufireman
Jun 28, 2008 05:32 AM
scat
Jun 12, 2007 03:11 PM
oregon dual sport
Jul 31, 2006 09:07 PM
