need help with shift star install!!!
ok, ive gotten everything apart and tryed to reinstall and had some problems. got everything back together and now it just sits in the neutral spot. i know its probably something silly i forgot cus its late, want my bike back on the road bad.
not exactly what im looking for. ive gotten everything back together (w/o the cover) and it doesnt seam to want to shift. before when i loosened or tightened it it would click threw the gear and now its not. also, the cover is being a 5 letter word and is really difficult to get it go flat back on, any ideas there.
Sounds like somethings not assembled right if it doesn't want to shift even with the cover off. With the shift shaft out can you rotate the shift drum around by putting an Allen key in the center bolt of the shift drum cam? You do have the shift drum cam installed correctly in the shift drum right? There is that alignment pin that locates and locks the cam to the drum is that installed and did you rotate the cam around until the pin went into the hole in the cam?
Sorry I've never had my cover off
1 Attachment(s)
Second paragraph /picture.
Is that lined up correctly - groove & pin? |
found the washer for the shift shaft broke, probably didnt seat right and when i cranked the case down it broke. new ones on the way. as for it not shifting, i read somewere that you need to move the motor some sometimes and sure enough it worked, so it will shift now.
