Need Help!
Old Dec 11, 2014 | 09:42 PM
Originally Posted by kotchman33
Watch the video, its topping out at 38mph in 3rd gear at 6500rpms
It should do better. You should get close to hitting the rev limiter.
Old Dec 11, 2014 | 09:43 PM
kotchman33's Avatar
Originally Posted by MattyTracks
I was thinking this, but you'd expect surging and sputtering, I didn't notice any of this in the vid. Seemed like the bike ran smooth up to 6500 rpm then hits a wall. What happens when you shift to 3rd or 4th?? I'm thinking something is amiss with the ignition system...check and replace the plug.
When I shift up it stays at 38 but just in lower rpms. Ill get a replacement plug tomorrow.
Old Dec 11, 2014 | 09:44 PM
durielk's Avatar
Don't some of these bikes have rev limiter in the lower gears? The FI ones? or?
I can't read the rev's. He can't be in 6th as his Rpm's would be much lower.
Old Dec 11, 2014 | 09:46 PM
kotchman33's Avatar
Earlier in the video that I had to edit out because the camera came loose, I shifted into 4th and it stuck at 38mph but at 4000rpms
Old Dec 11, 2014 | 09:48 PM
durielk's Avatar
I don't think it is the plug. It sounds like it is firing fine, althought there is that screaching sound???
I would suspect the carb (slide mafunction) or electronics.
Did the bike ever run right?
The previous owner did something to it.. or not, regardless, it is very difficult to figure out what is wrong without some major removal of parts. My suggestion is take in to a 'real' shop and let them figure it out. I doesn't sound like your up to the task.
Old Dec 11, 2014 | 09:51 PM
Brieninsac's Avatar
Are you sure you didn't buy an KDX 80?
I have nothing to add, but I'm curious to what this turns out to be. Definitely head scratching.
Old Dec 11, 2014 | 09:52 PM
kotchman33's Avatar
That screeching sound is not there, just the camera mic going weird on me
Old Dec 11, 2014 | 09:55 PM
  #28
kotchman33's Avatar
I rebuilt a 2004 125 ttr so I am able enough to fix it up if I know what is wrong
In other words, I know how to fix it, just not what to fix. Still an amateur for troubleshooting
Old Dec 11, 2014 | 10:56 PM
  #29
IIRC, yes the FI units have rev limiters in the upper three gears. Not sure where it limits, but this bike has a carb.
Old Dec 11, 2014 | 10:57 PM
  #30
.... Still an amateur for troubleshooting
You picked a fine project to get some experience!
