Mr. 2009 has left the building???
Old Mar 26, 2008 | 04:38 PM
Default RE: Mr. 2009 has left the building???
Actually the dealer that I got my bike from has it listed as 34.8 I know that's almost the same, but I wonder if the motor is closer to the ground, but they bumped the suspension up to compensate. Not sure on that one. Yea it does sound a little strange.
2009 KLX Specs
This is all from the same spec sheet that all the dealers use. I think its some sort of template from Kawasaki.
2006 specs
Specifications:
Engine Type: 4-Stroke, Liquid-Cooled, DOHC, 4-Valve Single
Displacement: 249 cc
Bore & Stroke: 72.0 x 61.2 mm
Compression Ratio: 11.0:1
Carburetor: Keihin CVK34
Ignition: Digital CDI
Transmission: 6-Speed
Rake/Trail: 26.5°/4.2 in.
Front Wheel Travel: 11.2 in.
Rear Wheel Travel: 11.0 in.
Front Tire Size: 80/100-21
Rear Tire Size: 100/100-18
Front Suspension: 43mm Inverted Cartridge Fork with 16-Way Compression Damping Adjustment
Rear Suspension: Uni-Trak with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment
Wheelbase: 56.5 in.
Front Brake Type: Disc
Rear Brake Type: Disc
Fuel Tank Capacity: 1.9 gal.
Ground Clearance: 11.6 in.
Seat Height: 34.8 in.
Dry Weight: 262 lb.
Color: Lime Green
Old Mar 26, 2008 | 04:52 PM
Hmmmm they are listing the 06 and the 09 as exactly the same weight. I wish Kawi would get their act together.
Old Mar 26, 2008 | 06:03 PM
09KLXowner's Avatar
Banned
ORIGINAL: deej
where did you see that? I see the two older ones at 262lbs. and the new one at 277lbs. Ground clearance is virtually the same as well on the new bike. I've got two questions on the new bike: how does seat height increase as susp. travel decreases; and how does weight increase with no rack and virtually the same bike? I mean thicker spokes will not account for 15lbs. of heft. If anything, weight should have decreased with the elimination of that rack I personally didn't care for. Nobrakes always has a logical explanation for everything, maybe he can add some light to these questions or maybe he doesn't really give a rats ****.
Old Mar 26, 2008 | 06:05 PM
Kohburn's Avatar
heck you can gain 5 pounds just from using different tires.
Old Mar 26, 2008 | 06:23 PM
09KLXowner's Avatar
Banned
we're talking 15lbs. here though and the tires aren't any larger than prior years. I'm just wondering if someone earlier hit it on the head with maybe an underquoted or inaccurateweight on the old bikes.
Old Mar 26, 2008 | 07:01 PM
warski's Avatar
That new rear swingarm must be really heavy...
I wonder if the new evaporative emmissions system that makes the bike California legal is on every bike? How much does that weigh?
I check the specs on the Kawasaki page vs. the specs on my dealers website. It appears that the template on the dealers website has not been updated...
Old Mar 26, 2008 | 07:14 PM
Click on the 2009 specs I posted above. Dry weight 262, but really weight is all relative, I mean I've taken a dump and lost that much.[8D]
Old Mar 26, 2008 | 07:17 PM
Yea it sounds like there are as many different answers out there as there are bikes. Oh well. Who cares about what a bike weighs. The KLX could have weighed 300 and I still would have bought it. Oh and as some of you know I also would have paid $10,000 for it, but that's just me and the way I feel about the bike. Its all good.
Old Mar 26, 2008 | 07:28 PM
09KLXowner's Avatar
Banned
ORIGINAL: deej
dude..............................[:-]
Old Mar 26, 2008 | 07:43 PM
ORIGINAL: 09KLXowner
ORIGINAL: deej
I know.....I know...I'm not helping. Sorry. Copy and paste can get you into trouble, I know that now.
