Modified side stand
My wife has struggled with the side stand on her KLX ever since she started riding it. With the bike being lowered, she had to tip the bike pretty far over just to get the stand down, and was afraid of dropping it. So I shortened it for her.
First I cut 1.25" out of the middle of the stand to compensate for the bike being lowered, sleeved it with a scrap piece of pipe I had lying around that was a perfect fit (to make sure I had it aligned properly for welding), then had a buddy weld it back together, and also had him weld on a foot pad that I cut out of some 1/8" steel plate I had lying around the garage. http://i172.photobucket.com/albums/w...psd6b82914.jpg |
Nice work!
I never noticed but the "09" on bikes have quite a different spring to hold the stand up when not in use. |
A rider, who got in touch with me about a part, and I were talking about this. He had a lowered bike and was thinking about the side stand.
One thought that came to mind was to make the stand adjustable in the event the bike either needed further lowering, raised back up, or just to avoid cutting it too short. The thought was to cut the stand, then thread the metal in each side with whatever tap fit, then thread in some all thread rod (or sawn off bolt thread) with locking nuts to allow the stand to be lengthened or shortened as desired. No welding if the stand tube is thick enough to thread (fine thread would be best since it wouldn't cut as deep). The rod would be quite large diameter so strength should be good. It could also be done by welding a bolt shank with the head cut off into one end with the other end threaded. If someone tries it, let us know how it works. |
678, ^ this has been done before. It's around here somewhere. I believe they welded a nut on.
Originally Posted by dan888
(Post 504106)
Nice work!
Originally Posted by IDRIDR
(Post 504110)
ADVrider - View Single Post - Long term KLX250S review I considered going that route, but decided to just measure very carefully and make sure I got the length right the first time. The bike has been lowered for over 2 years now, and I'm pretty sure it won't ever be going back to stock height. If it does, I'll find a way to deal with it then... |
Nice and clean work. Speaking of clean, what's up with that chain? Happy Thanksgiving to all of you.
Originally Posted by BillMoore
(Post 504115)
Yeah, here is the adjustable version (from ADVRider):
Originally Posted by NEWPARTSRULE
(Post 504116)
(Post 504110)
