Modification checkup?
Old Sep 6, 2007 | 02:06 AM
green242's Avatar
Default Modification checkup?
I just finnished re-jetting my bike, used a Main jet 2nd #128 , replaced the needle with the N1TC four position one. The clip on the 3rd slot from the end. The mixture screw out 2-1/2 (900 degrees counter clockwise) full turns out from the original position. I also put the KDX snorkle in and I have a K&N air filter installed.
These are the only mods I have done, and wanted to check that these would be safe for my bike, and most effective.
Old Sep 6, 2007 | 02:34 AM
klx250s_rider's Avatar
Default RE: Modification checkup?
Are you using the oem muffler? If so, get a slip-on or full exhaust asap!
Old Sep 6, 2007 | 03:15 AM
Truckman's Avatar
Also i'd strongly suggest installing an outerwears on the K&N.......when you see what it traps and the time it saves you ....you will thank me later.
Old Sep 6, 2007 | 07:42 AM
MaverickAus's Avatar
I'd replace the K & N with a foam filter
Old Sep 6, 2007 | 08:32 AM
tremor38's Avatar
+1. Must be that people think K&Nsounds cool or something.Might as well use some window screen and rubber band.
ORIGINAL: MaverickAus
Old Sep 6, 2007 | 09:33 AM
UNI....... K& N lets too much dirt through..... if your runnin stock exhaust, might wanna go to the second clip position from the top, the 128 sounds a little rich for a stock exhaust, thats the jet i used for my bike with the big gun full exhaust.
Old Sep 6, 2007 | 09:52 PM
green242's Avatar
Thanks fellas.
Now whatsymptoms will it have ifif it is running too rich / lean?
Is it harmful to the bike now with the stock exhaust?
Will it run better with a smaller jet, or any other cheap parts?
For the record
I have 07', 4200kms
NavKLX
Feb 3, 2015 04:00 AM
Ryan
Jul 16, 2007 09:49 PM
DJFields
May 2, 2006 12:44 AM
Mr. Toad
Ninja 250R
15
Apr 24, 2006 08:58 PM
incabiker
Mar 15, 2006 11:45 PM
