Missing a beat
Old Apr 24, 2012 | 03:09 PM
treerat's Avatar
Default Missing a beat
I had issues last year of the bike quiting on me at random. Only happened twice. I rejetted the bike this spring. Now it seems to miss a beat here and there. Not really noticable, just feels like it misses. Happens normally at cruising speed. I haven't done the kick stand yet, probably should. What's the correct way to disable an 09 kickstand.
Old Apr 24, 2012 | 03:36 PM
jeffzx9's Avatar
(Hmmmmmmmm, fuel delivery issues or electrical issues?)
Old Apr 24, 2012 | 03:48 PM
Follow the wires up from the stand switch to under the seat, and unhook the two wires and connect the two from the bike, and tape off the wires from the switch.
Old Apr 24, 2012 | 06:08 PM
cmott426's Avatar
I removed my switch completely.
Sounds like you are a bit lean in the mid range. Maybe raise the needle one notch.
Old Apr 24, 2012 | 06:28 PM
treerat's Avatar
Running DJ 116 third notch. 2 7/8 turns out. Stock snorkel and uni filter. Hard to believe i'm lean, but you might be right. MPG dropped from 60 to 52 city. Getting 45 highway.
Old Apr 24, 2012 | 10:01 PM
wildcard's Avatar
if its an 09 or newer you may need to do the rectifier ground mod. Fixed the cruising RPM miss i was having.
Old Apr 25, 2012 | 04:21 AM
2007 Green Machine's Avatar
I should do this now since I have my bike all apart for the 351 upgrade.
finzel
Jul 24, 2009 10:24 PM
TUCAZ520
Jun 22, 2008 11:14 PM
mfdanna
Jan 6, 2008 04:52 PM
ktn
Jun 5, 2007 04:37 PM
jared
Ninja 250R
Jul 16, 2006 11:13 AM
