minor vandalism
get a hitch mount bike carrier for your vehicle if it has a receiver
park bike on the carrier, problem solved with one vehicle per spot
could even get one of those 5 inch hitch extensions that can raise the carrier up by 5 inches, but install upside down
then you may not even need a ramp to get on the carrier, if its floating over the ground couple inches attached to the truck what can they say then
Really simple..Maybe..take your key and a hammer and Pound your key in the gas cap lock.once in.. open it up and remove your cap from tank.now once off take apart,order replacment tumbler from Kawi.useing you Vin.#...install done.might need a key because you might of damaged it in the cap also....I have done this to damaged locks...
meeting with the insurance adjuster today...after inspection and check is given to me, i'll mess with it and try to open it....i'll probably order the 3.0 gallon ims gas tank...
looks like you can buy a locking screw cap...acerbis gas cap - cap/locking - part number 2070769999
IMS 3 Gallon - Locking Gas Cap AND Tank Strainer
just called and left them a voicemail to see if they have the gas tanks in stock or if it ships directly from IMS....thanks...didn't think of them...
Good for you. I got my Acerbis from them and really appreciated their service.
