Mikuni TM33 jetting....
I did the 351 kit from Bill Blue. I also bought the TM33 pumper carb. The assembly went well. Bill noted that the carb was jetted 40 pilot and 140 main. I also ordered an FMF Q4 exhaust. When I started the bike, I had the stock exhaust. On the first test ride, there was bad hesitation. I worked on the needle and got the idle good and it helped the hesitation. I still would not pull more than 7500 RPM. I decided to wait for the exhaust and Bill Blue advised that I should try the 142.5 main. Both went on today. I still have the hesitation and it will not pull more than 7500-8000 RPM. Any suggestions? Thanks,
Don
2006 KLX250s, 351, TM33, 40 pilot, 142.5 Main, FMF Q4.
Don
I have basically the same setup as you - 351, Tm34 with fully Muzzy. I'm running a 40 pilot and a 145 main. Elevation is about 1300 - runs great through the full range.
I'd try to be a little rich over lean, especially at break in.
Jeff.
Hey - does the Q4 come with a bigger head pipe?
Jeff.
