Mikuni TM 36-2 versus Mikuni TM 36-68
I have considered that and the VM36. Either one could work, but the accelerator pump set up on the 68 makes it the best choice. The TM36 and VM36 have been used on four strokes, one of which I have had experience with being the Yamaha SR500. Works great on them. They are a bit simpler design. For me the only problem is they don't have any established jetting base line to work from I was seriously considering the 2 until I came across a used 68.
A lot the four stroke off roaders have slide carbs without accelerator pumps and work fine. Just that no one has published any info on this application that I could find.
George, the real advantage of using the 36-68 is the fact that it has an acceleratory pump. The real bonus isn't the extra 2mm of carb throat, so I think you'd waste your money and time putzing with the other 36.
On my 36-68 I do notice a marginal improvement from that 6000 rpm to redline WFO response, but that's compared to the stock CVK34. If you're going to swap carbs, go straight to the 36-68. My KLX has the factory KLX300 cylinder and piston with complete aftermarket exhaust. The 36-68 was well worth it IMO.
My problem is import tax.
I have bought an IMS tank. I need to use it before i go on a 5000km tour of Indonesia. The fuel tanki have is a carb model. So i am looking at options, as my bike is an EFI.
Change to carb.
Use a remote fuel pump regulator.
Or modify the tank.
Still havn`t decided which way to go.
Another tank is $ 500 plus with import tax.
A 36 - 38 is about the same.
So im looking for a solution but dont know what to do yet,
Thanks
George
Change to carb.
Or modify the tank.
Thanks
George
I would think you could pick up a CV carb a lot cheaper and jet it a lot cheaper than either. If your touring, CV carb would work fine. Slide carb is a big change in low end snap mostly.
I have been looking round, There is a guy here offered me a 36 - 68 pumper for $600 . Crazy,, So i Think i am going to try and modify the IMS tank to take my fuel pump ,
I'd find out the fuel pressure/flow requirements and get an external fuel pump. They make 'em every day for cars. If one can be had that is small enough it could be clamped to the frame like a remote shock reservoir.
Here is a link to Jegs. Odds are you may find something like this in the tuner car market in Indonesia. Do some searching.
Yes, I was thinking about that, But i couldn't find out what the pressure and flow rates were., I have emailed a specialist company who make after market fuel pumps but they didn't reply.
If you check with a Kawasaki dealership they could probably give you the OEM unit specs they would use to test one. Might even be in the KLX shop manual for the EFI bike. Or if you still can't find specs, see if you can test the pressure and output on yours. Probably want to know current draw and output in pressure, I doubt volume would be much of a concern when using an automotive pump. Every auto pump I saw on line either had the gallons/hour or pressure.
Fuel Pressure (High Pressure Line) 294 kPa (3.0 kgf/cm², 43 psi) with engine idling
Fuel Pump:
Type Wesco pump
Discharge 11 mL (0.37 US oz.) or more for 2 seconds
Fuel Pump:
Type Wesco pump
