Master link pliers (home made)
5 Attachment(s)
I recently saw some pliers made especially for removing the keeper on a master link. I think they were made by Motion Pro and were ~$20. It gave me the idea that I could modify a pair of my own pliers.
I ended up seeing a pair of linesmans pliers at Menards for $2.99 and off I went. Attachment 16667 Ground one side of the jaws shorter. Attachment 16668 Used the Dremel to cut a pocket in the short jaw. ( Use a carbide bit or some type of grinding wheel, I used the carbide bit.) You don't have to cut this pocket but it helps locate the pliers on the master link pin. Attachment 16669 Use it!! Attachment 16670 Attachment 16671 A decent pair of pliers work without the mods, but the mods make it childs play to get the clip off. Now I can clean that chain. Dan |
nice idea. home made tools are the best.
In my best Ronald Reagan voice..."well Dan, there you go again.":D
The stuff you come up with, I'm wondering if you were that MacGuyver guy.;) Darn good idea, really. |
I think Ill make me a pair and put it in my KLX bin
Thanks Dan |
Thanks a lot for that - the simplest ideas are always the best.
Nice tool for when your in the garage.
In the tool belt on the trail I prefer a pair of needle nose vice grips. Use them to press the side plate on even w/ o rings and removes/installs the clip easily too. Seen them used as a emergency shifter in a pinch |
