Making some progress on the klx300
Old Dec 18, 2017 | 04:20 AM
Garybusey's Avatar
Default Making some progress on the klx300
Front went together like a breeze
Here’s my attempt at a spacer
Found some braided lines on eBay off an old klx the 320mm rotors worked nice
My seat doesn’t sit right because my shim for the pumper carb needs to be reworked
Looks rediculous, I really need to fix my tank spacer for the pumper carb
Here’s hard earned money and a wheel that rubs the chain.
My **** is so ghetto. I’ve got chain rub on my rear tire and not sure what to do. Made a spacer out of an old sprocket but who knows how safe that will be.... here are some pictures
Old Dec 18, 2017 | 03:17 PM
What size tire? You should run a 140. You can sand the left edge with a sanding block spinning the tire.
Old Dec 18, 2017 | 05:25 PM
Garybusey's Avatar
150/60/17 I thought I could get away with it and have a little chain rub but it’s definetly more than a little. I’ll have to order a 140 now. Are you saying like sand the inside edge of the tire haha, i can see how that would work but I think I’d have to sand like a good inch haha. Might be better if I take this off and try and sell it for a fraction of the price, it’s a diablo 3 Rosso.
Old Dec 18, 2017 | 09:29 PM
wildcard's Avatar
Looking good. Shame about the tire. Some have reported 150's work fine and others say they rub, must be a luck of the draw on tire shape and true width. Need to get myself a new set of tires spooned on for next years track season.
Old Dec 19, 2017 | 01:37 AM
Garybusey's Avatar
Yeah this stuff never works out right and it’s a klx300 which makes the money I’m spending on it lkind of painful, but it’s such a fun bike. Yeah it’s not the quickest and yeah it’s not lots of torque but just fun as hell to ride.
Old Dec 19, 2017 | 03:36 PM
True width is the trick with tires. I attended a Honda seminar back in the 80s. Bridgestone rep pointed out there can be significant differences in width because there is about a +/- 50 mm allowance. The trick is to look up the tire manufacturer and see what they have for the actual inflated width/rim size to see what may work. Back when a Metzler Lazer 120/80-16 was essentially slightly larger than a Dunlop 110/80-16. The Metzler 130/80-18 was dwarfed by the Bridgestone 130/80-18. You do need to research actual tire sizes to know for sure.
Old Dec 19, 2017 | 04:30 PM
Brewster's Avatar
+/- 50 mm is almost 2 inches. That sounds like a very sloppy tolerance. Is there a missing decimal point?
Ride on
Brewster
Old Dec 19, 2017 | 10:44 PM
Yes, it should be +/- 5mm. I got too much metric on the mind... teaching robotics and doing stuff in cm and inches, getting confluzed.
Although there was nearly 2" on that old Metzler and Bridgestone.
Old Dec 20, 2017 | 09:03 PM
s10gto's Avatar
Nice Sumo! I like the Continental Attack SM tires. Purpose built for SM. They have a straighter side wall for chain clearance and are H rated for quick warm up.
avalaugh
ZZR 600
25
Oct 14, 2019 11:00 PM
Garybusey
KLX300R
Dec 18, 2017 04:10 AM
deej
Nov 20, 2007 12:55 AM
walight01
Aug 16, 2006 06:27 AM
shon
Aug 25, 2005 11:24 PM
