Lowering my KLX250.
i have a pair of kouba lowering links (model klx4, I think) and a already cut/lowered kickstand, that I would probably sell to you. lowers the klx250s about 2 inches. I am now back to stock. let me know
Hmm, I def don't wanna drop it to low for my weight and ruin my chains. I just wanna get it a bit lower. So, if 1 inch is all I can really do to drop it then, I guess I can do that. But, I was also thinking of getting a Coshing cover for my seat cuz, my has goes numb after 2-3 hours of riding lol.
I was kinda disappointed when i got my klx 4 months ago about how high it was, I'm 5'11 240. It wasn't the actual height but the way you have to swing your leg over it to get on it from the ground. Then I had an epiphany, I thought there has to be an easier way to get on and i thought about riding my horses. Now i put left foot on the left peg while kickstand is down stand up and swing the other leg over just like you mount a horse, issue gone, height doesn't matter anymore. A simple thing if you havent thought about it before, and free
You might want to read up on how weak the kick stand tab on the frame is welded on. Kick stand tab 1/4" plate welded to that swing arm pivot 1/8" material. There's pics of the welded metal separating... Punkenduro and one other iirc
28" inseam
I have a Kouba KLX4 links and the forks up 5/8" to the bottom of the cap. Like the way the bike handles.
My kick stand all fixed after it was bounced off a few rocks and such.
I have a Kouba KLX4 links and the forks up 5/8" to the bottom of the cap. Like the way the bike handles.My kick stand all fixed after it was bounced off a few rocks and such.
the suspension is taking all the weight, the kickstand is just used for balance when you put your foot on the left stirrup(foot peg)
I really doubt there is much issue with the side stand mount since it is probably very similar to that of the KLX300 frame and they use a kick starter - I guarantee you most will kick start their bike on the side stand.
The post about weight distribution is true as well, the weight is split between the two, tires and stand. Plus the fact that the weight is not in a bending direction to the tab as welded on the frame. So the concern is minimal at best.
Now if you use the side stand to pivot the bike around in a tight space you could be putting some serious weight on it. Fact is you probably put more stress on the stand by just sitting on the bike, because when this method is used for mounting the rider will likely have their feet on the ground in a few seconds, making for less stress for a shorter time. I step up on the bike and am on the seat feet on the ground in about 2 seconds after I get on the bike.
Ymmv...
My wife all 120+ lbs of her bent her kickstand frame tab just by sitting on the bike. Punkenduro did put a lot of miles on his 250... Take a look https://www.kawasakiforums.com/forum...e-25055/page6/
Had John @ MotoPro shorten my suspension 2 inches. He re valved and re sprung it for the roads and speeds that I ride hardest. I love it, everywhere. Not cheap and worth every penny. Thank You John. You Nailed It.
