Lowering links
As novasteve said above, shorter links will raise the ride height in the back, but they will not change the travel of the shock - only a shock modification will change the travel. But if Kawi did not reduce the rear travel and the rear shock is the same as the 06/07, and they lowered the right height purely by installing longer links, then reverting back to the 117mm link will do what you want, I think. If Kawi additionally revalved / resprung the 09 shock to compensate for the increased leverage on the shock due to longer links, then you will have the reverse problem of the OP in this thread - i.e., the shock will feel stiffer. That might be a good thing, though.
As for the front, I'm def not a suspension guy, so what I would do is find a local suspension shop, take the forks to them and ask them to "fix" it. For a good local shop, check your local hare scramble association web site and message boards, usually there are one or two local suspension guys that take care of all the local racers. That's who I would go to.
The internals will come out, though, by loosening up the bolt from the bottom. An air wrench might be needed, not because it is tight, but the whole inside may turn with the bolt and the air wrench can overcome that. I haven't actually taken that end apart, though, all I did was replace the spring and you just remove the top cap for that and you never really need to get too far inside the fork when you do that.
I was amazed at how changing the bikes geometry just a little bit effected handling so drastically.
Changing the height of the bike is definately not as easy as simply changing links. It's kind of like adding more air flow to the engine, it's a multi dimensional process. I think the suspension is more complicated though.
The 250 and I weigh about the same and a stiffer setup would be a good thing.
Do I need a new shock or will a beastier spring do?
Does anybody know if any of the larger CC KLX or DRZ shock/spring setups will cross over to the the KLX 250 with minimal mods ??
kdick91
Jun 25, 2014 09:00 PM
