Loose flywheel bolt
Old Mar 28, 2021 | 11:38 PM
ldkr's Avatar
Default Loose flywheel bolt
I've had my KLX250s on the stand for a while and after getting back to it found the piston was stuck. I tried turning the crankshaft with the flywheel bolt (under the left side cover) but it was stuck enough that I loosened the bolt. I've tried tightening it (88ftlb) by putting it into 5th and having someone sit on the bike/brakes but that's not enough resistance. It looks like I have to drain it, take the starter part way off, replace gaskets, etc etc. And will need some sort of tool to hold the flywheel... Is there any way to tighten that bolt without digging in deeper?
Old Apr 27, 2021 | 08:22 PM
Asafs's Avatar
was the grasp bolt twisted down appropriately, u have 2 go in arrangement till Every one of the bolts are forced appropriately cause u are pushing down a spring(the pressure plate). did it get nbow bolts, I generally supplant all mine occasions 2 err on the side of caution cause I have known about them shearing off before. 192.168.100.1 192.168.1.1
Old Apr 27, 2021 | 10:42 PM
durielk's Avatar
U use a flywheel holder tool, did you look at the manual?
Nikolaj Lykke
Jun 19, 2013 08:51 PM
jglow
Mar 6, 2010 10:28 PM
jaylaudeman
Aug 31, 2008 04:28 AM
jamieislimegreen
Ninja 500R
Mar 16, 2007 10:41 AM
shelby
Aug 20, 2006 08:19 AM
