Looking for rear ugly mudflap thing for an 09'
Anybody have one they took off? The piece the tag mounts to?
I want to mod mine and want another just in case. Thanks |
I have one that was taken off with no miles on it. Make me an offer. An offer I would really like is a clutch perch for an O9. I made a trade with another member and ended up with something different(mirror does not fit)
If you are willing to order and send out a Complet clutch perch and switch(dont need the lever) Ill send you the rear mud flap assy with light and license plate bracket.(all new) |
Humm. Maybe.
Go ahead and mod what you got, I took masking tape and made the shape I was looking for, then cut along the outside with an air cut off tool. Then went back with a block sander and fine paper and cleaned up the cut and IMHO it looks great. I had installed an edge system on mine and from certain angles from the rear you couldn't see the tail light. I took it off and modded the stock one and I like it as well if not better.
I just took a grinder to mine the first day I got it from the dealer....turned out fine and I did it by eye
Can you guys post some pics of your cut tail. I was going to install the edge but after reading I think I'll cut mine first.
I cut mine last night. I decided I didn't like the Edge light hiding up under that plastic tail piece. I masked off the area I wanted to cut. I also masked over the light, as I cut it with the light in place. I took a cut off wheel and my cordless drill and went after it. Then I took some sandpaper and cleaned it up. Took about 20 minutes.
http://i20.photobucket.com/albums/b2...y/DSC01101.jpg http://i20.photobucket.com/albums/b2...y/DSC01100.jpg |
I hated the way mine looked, so I flipped the plate bracket, and cut it right below the plate.
Now I kinda wish I hadnt done that, I get a good bit of mud and water thrown up on the back of the bike and even me at times. |
You can see mine in a recient thread called "DOT knobs installed". It's visable in a couple of the photos I posted.
3 Attachment(s)
i just cut alot and mounted the plate with 2 new screws that hold the tail light on
