Look at this setup/color scheme
Old Nov 29, 2006 | 05:25 PM
markturbo's Avatar
Default Look at this setup/color scheme
Saw this over on Advrider, I really like the look!
Old Nov 29, 2006 | 05:28 PM
cwgoff's Avatar
Default RE: Look at this setup/color scheme
+1. I saw that over there as well. Very sharp.
Old Nov 29, 2006 | 06:18 PM
cool... but i like the green.... thats probably a dtracker from japan....
Old Nov 29, 2006 | 06:43 PM
markturbo's Avatar
ORIGINAL: EMS_0525
Nope, he converted it over.
"Hey there, I have read the threads on here many times, and thought I would share a pic of my bike. It is a 2006 klx250s, converted over to a supermoto. I have had it on the trail a few times, but it is my daily driver (approx. 30 miles a day). Bought it back in february, and it has about 7000 miles on it.
New Parts Include:
Plastic shrouds
Fenders
Headlight
Taillight (LED, bright as sin)
Turn Signals
Lowering Links
Kickstand Cut down
Seat Cover
Air Box Mod
Parts that are going to be changed:
Exhaust
Carb
Jet Kit
Bars
Levers/Grips"
Old Nov 30, 2006 | 10:52 AM
tremor38's Avatar
Yep. The shrouds and side panels are from a D-tracker. Actually, you can make this bike look exactly like a D-tracker for about $500.00..although most wouldn't go so far as to use the the stock head plastics or rear fender/tail light combo.
ORIGINAL: markturbo
ORIGINAL: EMS_0525
New Parts Include:
Plastic shrouds
Fenders
Headlight
Turn Signals
Lowering Links
Kickstand Cut down
Seat Cover
Air Box Mod
Exhaust
Carb
Jet Kit
Bars
Levers/Grips"
Old Nov 30, 2006 | 01:33 PM
hey tremor, does the d tracker still have the same sprockets on it? 14 and 42? what about the exhaust, does it have the catalyst in it? just curious, o yea , what about the smog stuff?
Old Nov 30, 2006 | 02:09 PM
markturbo's Avatar
Wonder where he got those white shrouds?
Old Dec 1, 2006 | 12:08 PM
MaverickAus's Avatar
ORIGINAL: EMS_0525
I can answer part of the first question for you EMS the D-Tracker uses a 39 tooth rear sprocket
Old Dec 1, 2006 | 05:03 PM
tremor38's Avatar
The exhaust and smog stuff are exactly the same as stateside KLX250...with the exception that there is no EPA tamper plug on the fuel screw. As a matter of fact, I just plugged-off my smog plumbing and removed the big clunky vacuum operated valve/hoses from the top of the valve cover. Like Maverick said, it uses a 39 toot rear sprocket and 14 on the CS.
ORIGINAL: EMS_0525
Neosporin
Aug 23, 2014 05:27 AM
jhoffy22
Mar 31, 2012 03:45 AM
deej
Mar 8, 2011 01:24 AM
nastybutler
Ninja 500R
Aug 13, 2007 09:36 PM
frrogger1
Mar 9, 2006 08:30 PM
