Long shot - but anyone have a left side crank case they want to sell? (2007)
maninthesea - sent you a PM a few days ago..
Side note - anyone that's removed the motor on this bike.. The manual calls to remove the right side peg.. Is that really needed? Reason I ask is because the bolt on the RS peg is chewed up a bit and I can't get it off without chewing it up some more.. I'll just leave it if it doesn't need to come off..
Thanks
Thanks
Well the motor is out.. Wasn't too bad, just a lot of stuff to disconnect.
Also got in the mail yeasterday - all new gaskets, new timing chain, new head gasket, new piston rings, swingarm bearings, steering stem bearings, and probably some more stuff I'm forgetting.. It should be like a new bike when I'm done with it!!!
I can't wait to ride. Between this damage and my injury, i's been almost 4 months!! Just got my cast off my hand a couple weeks ago. The surgery appears to have been a success, my thumb no longer pops out of it's socket at random times so that's good
I can't wait to ride. Bring on Spring!!!!
Marine tex
http://www.marinenutz.com/products/M...Set-Paste.html
Also available on Amazon
http://www.amazon.com/Marine-Tex-Rap...8648333&sr=1-4
This will work especially if you get to both sides and rough up the surface. I used it on an old Honda CB on the cylinder head when the cam roller sprocket came through. For reals it the shiznit!
Note: I'm probably too old to say shiznit huh?
deej - my father works for an aircraft manufacturer, he gave me some military grade aluminum welding compound to use. He said they use it on military aircraft in the field when conventional welding is not possible. Not sold to the public, it's good stuff
Anyways, I will first see about getting it welded professionally.. If I can't find someone to do cast aluminum, I will be going the chemical route.
I'd rather get a real weld, but from what my dad says, this stuff will be more than enough.
With welding it, isn't there the chance of distorting the case unless the welding is done with the cases assembled at the correct torque? I'd go with that hi-tech bubblegum.
Let me know how the steering stem bearings go! That was the one I was thinking might be the PITA.
I dunno. I guess it can't be any worse than what I'm in to already!
And I keep hearing mixed stuff about welding the aluminum case.. Some say to do it, some say to not do it, some say to use the magic putty, some say not to.
I don't know.
My father has 30+ years doing this type of stuff on Military aircraft and he told me this stuff will work like a charm and I won't have to ever worry about it. Maybe I'll just go that route.
I just don't want to ever have to do this job again!
I don't know.
If the magic putty is good enough for things that fly all the time, it should be fine for something that is only in the air once in a while.
Just be sure to do the prep as directed.
