Liter bike style air box for our 1/4 liter
Old Jun 25, 2014 | 04:00 AM
mod40car's Avatar
Default box
Why not remove the box completely and run a bolt on filter right off carb?
Old Jun 25, 2014 | 04:35 AM
Richard Avatar's Avatar
Too much heat from the exhaust, engine, and radiator would get sucked in IMO.
Old Jun 25, 2014 | 04:35 PM
RockabillSlapMatt's Avatar
I disagree, run a pod filter off the left or right side, sticking slightly outside the frame, and you will get nothing but cooler air at speed
Old Jun 25, 2014 | 10:35 PM
A year or so ago I measured a 6F degree temp difference using an indoor/outdoor thermometer something like this comparing ambient temp vs temp inside the air box of my air cooled XR200 under load "at speed".
My Kaw gets much much hotter in and around the frame than the XR
I think the only side for an angled neck filter is the right side which would be directly above the exhaust.
Mototune man has a page about the 10hp loss you get when removing the heat shield on 4 cyl bikes allowing radiator heat to toast everything behind it.
Bad enough the metal gas tank turns into a mini oven sitting directly above the hot engine.
Old Jun 26, 2014 | 03:43 AM
mod40car's Avatar
Default heat
Woud be interesting to see what temps the 250 run. I run pod on mine too and have raced for several years running pod types (K&N-UNI) and never had any problems but never gave it a second thought tho, because that is what we always ran.
Finger Mullet
Apr 25, 2008 07:32 AM
Sturgell
Jun 22, 2007 03:10 PM
e_fizzy
Jan 29, 2007 06:50 AM
flyboy110b
Feb 16, 2006 01:44 AM
a16tony
Jan 21, 2006 06:43 AM
