Lets see your rotors
Old Oct 10, 2007 | 03:28 AM
KLXer's Avatar
Default Lets see your rotors
Getting tired of the front brake..or lack there of.
Lets see your front rotor kits if you have them on stock 250S hubs. What size rotor, price, & what is the rotor "officially" listed for model wise.
Old Oct 10, 2007 | 09:10 AM
Default RE: Lets see your rotors
i think as far as better braking "kits" like tremor has mentioned the kx250 caliper and such bolts right up and has lots more stopping power, i am gonna get the steel braided lines her soon.
Old Oct 10, 2007 | 11:02 AM
MaverickAus's Avatar
I got the braided lines and it seems a lot better to me
Old Oct 10, 2007 | 11:19 AM
bryantjt's Avatar
Sometimes it seems like my bike has Bri....I mean no brakes. I've turned the plunger bolt in farther so there is less travel before hitting the plunger on the resevoir but just the same, it either pulls most of the way to the grip or every now and then it will have good pressure and have a good feel to it. I've got 7000 miles on it and the pads appear to still be in spec per the service manual, ~3mm of pad left.
Old Oct 10, 2007 | 11:25 AM
tremor38's Avatar
As far as the KX and KDX parts go, the KDX220/200rotor is cast iron (vs our steel) which makes a big difference in stopping power...it's a direct bolt-on to our hub. The KX master cylinder compliments this set-up by affording WAY better control of the braking. It also requires much lesseffort than ours and has ashort lever that you can easily operate using one or twofingers..Fits nicely underhand guards as well.No need to change the stock caliper as there is no gain from that.
I plan on changing to the KX master cylinder this winter..along with many other mod's.Being the motard freak that I am, I opted for a 320mm wave rotor witha smallerwavein the rear. At present, I am experiencing about a 30% increase in stopping power and it's much smoother. I'm fully expecting another very noticeable improvemnt when I install the KX master cylinder.
Old Oct 10, 2007 | 12:46 PM
KLXer's Avatar
Nice.
I think I decided on on the EBC supermoto kit--the full 320 mm not the smaller one I was originally thinking, but need to know which model bike to order it for. It is the same rotor that SM KLX on ebay right now has. Is your Braking rotor listed for the D-Tracker or some other model bike?
I have a braided line & while it is am improvement does not turn iron to gold.
Old Oct 10, 2007 | 05:30 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 10, 2007 | 06:10 PM
KLXer's Avatar
It had to come from somewhere. I have a KDX rotor in my garage. Ill have to see if it fits.
Old Oct 10, 2007 | 06:15 PM
KLXer's Avatar
Dennis Kirk lists EBC brake rotors as fitting all the below. Doesn't mean DK can't be wrong, but I have heard some say it will work, some say it wont. Ill know for sure when I try to bolt up my KDX rotor I guess. Is it possible the seller was not correct on which model & or year of the brake rotor he sold you was from?
[ul][*]Kawasaki - KDX200 1993[*]Kawasaki - KDX200 1994[*]Kawasaki - KDX250 1992[*]Kawasaki - KDX250 1993[*]Kawasaki - KDX250 1994[*]Kawasaki - KLX250R 1994[*]Kawasaki - KLX250R 1995[*]Kawasaki - KLX250R 1996[*]Kawasaki - KLX250S 2006[*]Kawasaki - KLX250S 2007[*]Kawasaki - KLX300R 1997[*]Kawasaki - KLX300R 1998[*]Kawasaki - KLX300R 1999[*]Kawasaki - KLX300R 2000[*]Kawasaki - KLX300R 2001[*]Kawasaki - KLX300R 2002[*]Kawasaki - KLX300R 2003[*]Kawasaki - KLX300R 2004[*]Kawasaki - KLX300R 2005[*]Kawasaki - KLX300R 2006[*]Kawasaki - KLX300R 2007[*]Kawasaki - KLX650A KLX650R 1993[*]Kawasaki - KLX650A KLX650R 1994[*]Kawasaki - KX125 1989[*]Kawasaki - KX125 1990[*]Kawasaki - KX125 1991[*]Kawasaki - KX125 1992[*]Kawasaki - KX125 1993[*]Kawasaki - KX125 1994[*]Kawasaki - KX125 1995[*]Kawasaki - KX125 1996[*]Kawasaki - KX125 1997[*]Kawasaki - KX125 1998[*]Kawasaki - KX125 1999[*]Kawasaki - KX125 2000[*]Kawasaki - KX125 2001[*]Kawasaki - KX125 2002[*]Kawasaki - KX250 1989[*]Kawasaki - KX250 1990[*]Kawasaki - KX250 1991[*]Kawasaki - KX250 1992[*]Kawasaki - KX250 1993[*]Kawasaki - KX250 1994[*]Kawasaki - KX250 1995[*]Kawasaki - KX250 1996[*]Kawasaki - KX250 1997[*]Kawasaki - KX250 1998[*]Kawasaki - KX250 1999[*]Kawasaki - KX250 2000[*]Kawasaki - KX250 2001[*]Kawasaki - KX250 2002[*]Kawasaki - KX500 1989[*]Kawasaki - KX500 1990[*]Kawasaki - KX500 1991[*]Kawasaki - KX500 1992[*]Kawasaki - KX500 1993[*]Kawasaki - KX500 1994[*]Kawasaki - KX500 1995[*]Kawasaki - KX500 1996[*]Kawasaki - KX500 1997[*]Kawasaki - KX500 1998[*]Kawasaki - KX500 1999[*]Kawasaki - KX500 2000[*]Kawasaki - KX500 2001[*]Kawasaki - KX500 2002[*]Kawasaki - KX500 2003[*]Kawasaki - KX500 2004[/ul]
[/align] [/align]
Old Oct 10, 2007 | 06:37 PM
Shadetree's Avatar
Guys, those wave rotors look like the deal! I installed Bill Blue's stainless steel lines front and rear and it made a huge difference on the front. It took a bit to get it bled properly, but once I did, it's all the brake I need for the dirt. Pavement might dictate a little more though.
My rear brake is ok, but just. It's better with the SS line, but I would like a little more power and feel.
Santa, maybe? Any suggestions as to what setup would be a good conversion?
Bill Dragoo
Norman, Oklahoma
KLX 331
Dyna Sport
