Labor to install BB TM34 carb
Old Apr 27, 2014 | 12:29 AM
smontalvklx's Avatar
Default Labor to install BB TM34 carb
I have a 2009 KLX250S with the BB351 kit, modified air box, FMF Q4 slip on, and jetted. I'm considering buying the BB TM34 carb, just a few questions:
1) This is not something I'm comfortable doing so if I have a mechanic do it here in Portland, OR area such as Cardenas about how much labor you think I would pay?
2) I do like to get on the freeway and cruise at 65mph from time to time, will this be the same with the TM34?
Thank you!
S
Old Apr 27, 2014 | 01:38 AM
Richard Avatar's Avatar
The engine rpm would be the same at 65mph with either carb, but the BB 34mm might get you there quicker..
I think the install itself is fairly easy. Someone who's done it will fill you in.
Old Apr 27, 2014 | 02:11 AM
durielk's Avatar
I guess you didn't wrench the 351 yourself. Changing the carb is pretty simple, I would estimate about .75-1.5 hours, some shops probably could give you their estimate if you talk to the service dept.
If the jetting isn't right, you'll have to have the carb pulled to change the jets. It becomes a labor intensive operation. If you think this is going to be an issue, you may consider just getting a dyno jet and forget about it. If your paying a shop to pull & reinstall the carb several times, the dyno jet is going to pay for itself fast.
Old Apr 27, 2014 | 02:41 AM
Thank you for the info I will contact Cardenas here in Tigard they have done work on a CRF I owned and they are very good! Do you guys have the bb 34mm? If yes how do you like it?
Old Apr 27, 2014 | 04:23 AM
durielk's Avatar
I got the 33/34 BB, a lot of the others have the 36, it is cheaper & has an adj pumper. It really gives the low in a kick in the ***. I think for the $$ & work that is the best mod before the 351.
Do a thread search and you can read up on it. Or just look at any TNC comment.
Old Apr 27, 2014 | 05:38 AM
By the way guys what's the normal
Idle rpms for the bike?
Old Apr 27, 2014 | 07:38 AM
mee2yoo's Avatar
Cardenas is now in Tualatin. Give him a call. Tell him Dave, from Motosport sent ya.
Old Apr 27, 2014 | 07:25 PM
kdick91's Avatar
1250RPM-1350RPM per the service manual. I like it at 1500RPM. As usual, only set when fully warmed up.
Old Apr 28, 2014 | 01:44 PM
Perfect thank you!
Old Apr 28, 2014 | 11:01 PM
Tell you what, just point your webcam at your bike and I'll guide you live as you do the install via Skype from SE Asia to OR..
Kind of like remote surgery
RockabillSlapMatt
Sep 3, 2013 03:05 AM
mee2yoo
Jun 29, 2012 02:40 AM
Fourty2ri
Sep 14, 2009 03:53 AM
MaverickAus
Jul 5, 2007 06:30 AM
klxstiffler
Sep 8, 2006 08:44 PM
