KLX351 Electrical Problem
Old Mar 30, 2013 | 07:51 PM
bajus22's Avatar
Default KLX351 Electrical Problem
So, I just finished putting together my 351 (for the second time, faulty head gasket). The bike started up fine and ran no problem. I went for a 30 km ride and stopped for lunch. On the way home, I was riding about 110km, when the bike surged and I switched to reserve. I made it into a gas station and the bike just died. I still had a good amount of fuel. Anyways I filled her up and the bike would barely crank over. The clock actually reset as if though the battery was disconnected. I had my buddies push start me and I made it home. I put the bike on the charger overnight. Went for a ride today, bike started up no problem. I went 100ft down the road and the bike died. I tried starting it, and same thing as yesterday, it felt like the battery was dead, and the clock reset again. I brought the bike home and checked the battery voltage, it was 11.8v. Any ideas why the bike is acting like it has a dead battery? Once I got the bike running again, I cranked it to 5,000rpm, and the battery was reading 13.8v. Is this enough voltage? Any help or ideas would be appreciated, thanks.
Old Mar 30, 2013 | 08:05 PM
batcave's Avatar
Hi
Sounds like the bike has a charging fault. Possible regulator/reftifier issues or the gererator is faulty.
Just a few ideas
Old Mar 30, 2013 | 08:06 PM
wildcard's Avatar
what year ?
Rectifier mod ?
Old Mar 30, 2013 | 08:34 PM
bajus22's Avatar
It's a 2009. And yes I did try the rectifier mod, but when it died the first time, I put everything back to stock.
Old Mar 30, 2013 | 11:59 PM
darkmarc's Avatar
Sounds like the battery to me. 13.8 volts sounds about right, so your charging.
How old is your battery?
marc
Old Mar 31, 2013 | 12:44 AM
bajus22's Avatar
It's the stock battery. The bike ran fine last season. I didn't start the bike all winter, did the rebuild to 351, and this was the first time I rode it this year.
Old Mar 31, 2013 | 01:31 AM
ol'klx-er's Avatar
Did you recheck all the electrical connections? Slightly loose ground etc etc
Did the battery just sit all winter or did it have a trickle charger? Outside, inside?
Old Mar 31, 2013 | 02:57 AM
klx4me's Avatar
It sounds like your battery is cactus. Is it 11.8v with key on, headlight on? The circuit should be loaded when checking battery voltage. A multimeter is low impedence and will not load up...
Old Mar 31, 2013 | 03:33 AM
durielk's Avatar
Your battery is toast.
Old Mar 31, 2013 | 04:05 PM
bajus22's Avatar
The bike was stored in an unheated garage, without a trickle charger. And yes it was 11.8v with key on, lights on. It dropped to 11.5 after about 3 seconds of cranking the engine over.
