KLX250SF motard
Hey guys... new to the forum and new 250SF motard owner.
Hopefully you can help. I am unfamiliar and don't trust the IRC Road Winner tires stock on this bike, but if they are like most stock tires then they need to go.
Are the IRC tires any good? They are the same exact tires front and rear as the Ninja 250R.
Any suggestions as to replacement tires that will be good and sticky for lean angle?
I have already started the planning process to do the 351 kit, FMF exhaust, etc. I might also do the FCR carb.
She needs more ponies and needs them bad. Although it's still a fun little bike stock.
Michael
Try these, they are the stickiest. Control tyres for motard racing in Australia. Some compounds are DOT legal.
Front M6118 Presa Supermotard.
http://www.maxxis.com/MotorcycleATV/...esa-M6118.aspx
Rear M6119 Presa Supermotard.
http://www.maxxis.com/MotorcycleATV/...esa-M6119.aspx
Yeah... I have about 30 miles on mine and have about 1/2" of unused edge still... I got a little slide off the rear but I am attributing it to still having some mold release on the tires and not fully scuffed in yet. But I am still looking at either the michelin Pilot Activ or the Pirelli Sport Demon 110 front and perhaps 140 or 150 rear. According to some websites I looked at, a 4" rear rim is the upper limit of a 130 tire... so I plan to maybe go 140 or 150. Still unsure.
I know on the older bikes, the rear tire can go up to 150, but you have to use a longer chain to bring the rear wheel further back in the swingarm, and some people even had to offset the spokes to one side to clear the chain. Once you go 150, the tire market for good street tires opens up a lot more options. Over here in Japan, they come with a 4.25 rear wheel for the motard version, which will hold a 150 just fine.
Well, after some closer looking at the bike, here is the definitive answer. A 150 tire WILL NOT fit. It would only leave a few millimeters of space to the right side of the swingarm... not enough room to take into account sidewall flex.
So, it seems that physically only a 140 rear tire will fit the swingarm with enough room to spare on the right side swingarm. There is plenty of room to the chain side and to the front, so the wheel will not have to be moved rearward.
