klx250s wikipedia page?
Old May 28, 2010 | 09:48 PM
punkenduro09's Avatar
Default klx250s wikipedia page?
anyone want to start one? there isnt one for us so i thought we would be the perfict people to make it. anyone good with that site, seams kinda complicated.
Old May 28, 2010 | 10:27 PM
aalegado's Avatar
I've edited Wikipedia pages but have never made one from scratch.
I suppose the easiest way to do this is to find one or two existing bike-specific pages to use as formatting examples and then just substitute the information for the KLX-250S.
Care to do the research (find some Wikipedia pages to use as examples and gather the KLX info) and then I can do the grunt work on Wikipedia?
Old May 29, 2010 | 01:38 AM
sure ill look up some stuff in a bit. just seams weird that have the klr250, the klx300 and nothing for us.
Old May 29, 2010 | 02:11 AM
Old May 29, 2010 | 02:27 AM
SPECIFICATIONS USA - 2009 Kawasaki KLX250S:
Engine: Four-stroke, Liquid-Cooled, DOHC, four-valve single
Displacement: 249cc
Bore x stroke: 72.0 x 61.2mm
Compression ratio: 11.0:1
Cooling: Liquid
Carburetion: Keihin CVK34
Ignition: Digital CDI
Transmission: Six-speed
Final drive: Chain
Frame: Semi-double cradle, high-tensile steel
Rake / trail: 27.5 degrees / 4.3 in.
Front suspension / wheel travel: 43mm Inverted Cartridge Fork with 16-Way Compression Damping Adjustment / 10.2 in.
Rear suspension / wheel travel: Uni-Trak® with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment / 9.1 in.
Front tire: 80/100x21
Rear tire: 100/100x18
Front brake: 250mm semi-floating petal disc with two-piston hydraulic caliper
Rear brake: 240mm petal disc with single-piston hydraulic caliper
Overall length: 87.5 in.
Overall width: 32.1 in.
Overall height: 47.1 in.
Ground clearance: 11.0 in.
Seat height: 34.8 in.
Dry weight: TBD
Fuel capacity: TBD
Wheelbase: 56.7 in.
Color choices: Lime Green, Sunbeam Red
MSRP: $4,899
Warranty: 12 months
__________________________________________________ ________________
Specifications: 2006 klx250s
Engine Type: 4-Stroke, Liquid-Cooled, DOHC, 4-Valve Single
Displacement: 249 cc
Bore & Stroke: 72.0 x 61.2 mm
Compression Ratio: 11.0:1
Carburetor: Keihin CVK34
Transmission: 6-Speed
Rake/Trail: 26.5°/4.2 in.
Front Wheel Travel: 11.2 in.
Rear Wheel Travel: 11.0 in.
Front Tire Size: 80/100-21
Rear Tire Size: 100/100-18
Front Suspension: 43mm Inverted Cartridge Fork with 16-Way Compression Damping Adjustment
Rear Suspension: Uni-Trak with Adjustable Preload, 16-Way Compression and Rebound Damping Adjustment
Wheelbase: 56.5 in.
Front Brake Type: Disc
Rear Brake Type: Disc
Fuel Tank Capacity: 1.9 gal.
Ground Clearance: 11.6 in.
Seat Height: 34.8 in.
Dry Weight: 262 lb.
Color: Lime Green
Warranty: 6 months
Good Times Protection Plan: 24, 36 or 48 months
* Price and specifications subject to change
__________________________________________________ ____________________
Year: 1979
GENERAL
Make: Kawasaki
Model: KLX250
Retail New:
Retail Current: n/a
WEIGHT AND FUEL ECONOMY
Dry Weight: n/a
Wet Weight: 250
Load Capacity: n/a
GVWR: n/a
Fuel Capacity: 2.5
Average MPG: n/a
Gallons to Reserve: n/a
Range to Reserve: n/a
CHASSIS
Frame: Single downtube full cradle chrome-moly frame w extruded aluminum swing arm
Wheelbase: 55.89
Seat Height: 36.70
Front Tire: 3.00-21
Rear Tire: 4.00-18
Front Brakes: 120 x 28mm brake shoes
Rear Brakes: 130 x 28mm shoes; full floating design
Front Suspension: Air/spring oil-damped forward-mounted axle fork w 9.8" travel
Rear Suspension: Gas-charged shocks w remote reservoirs and five preload settings, 9.8" travel
Instrumentation: n/a
TRANSMISSION
Clutch: n/a
Number of Gears: 5
Final Drive: Chain; 3.29:1
ENGINE
Engine Type: Single
Engine Displacement: 246
Bore x Stroke: 70 x 64
Valve Train: SOHC
Valves per Cylinder: 2
Valve Adjustment: n/a
Compression: 8.9:1
Carburetion: Single 32mm Mikuni
Ignition: Capacitor-discharge; magneto
Starting System: n/a
Lubrication: Wet sump
Cooling System: n/a
PERFORMANCE
Charging Output:
n/a
Battery: n/a
Power: 17.85 @ 8500
Torque: 11.81 @ 7000
Top Speed: n/a
RPM @ 60: n/a
Standing 1/4: n/a
0-60: n/a
let me know if you need more info, i dont start my new job till tuesday and im not going to havasu now cus my buddys wont be back till after tuesday, so ill just be drinking and watching the usgp online.
Old Jun 1, 2010 | 03:31 PM
bill622's Avatar
any update about this page? I might not know much about the KLX but I'm a web programmer and I use to have my own wikipedia for personnal notes.
I would like to help...
Old Jun 1, 2010 | 08:05 PM
aalegado's Avatar
Great work punkenduro09! I can get started on the page probably this Wednesday.
Bill622,
I was just going to take punkenduro09 work and create the KLX250S Wikipedia page. As I've said, I've only edited pages—never create one from scratch. If you've got experience with creating a page from scratch and you have the time then, by all means, take the info punkenduro09 has gathered and create the page for us!
I know I won't get to it for a few days.
Old Jun 1, 2010 | 08:13 PM
bill622's Avatar
It all depends on what kind of page we want. I think we could do something nice like this page for exemple:
http://en.wikipedia.org/wiki/Toyota_Corolla
I know it's a car page but the over all layout is interesting with different generation.
I can create it without much content in it. Do we want to add the "all Kawasaki models" box at the bottom like on this page?
http://en.wikipedia.org/wiki/Kawasaki_KLX300R
What do you think?
Old Jun 1, 2010 | 09:31 PM
redpillar's Avatar
Cool!
Old Jun 2, 2010 | 02:11 AM
gen to gen would be nice, but im not the one adding the page so im not stressing how it looks. it was just kinda odd there wasnt one. thanks for the help editting it, i would be sooo lost.
