KLX250S overcharging (its not the volt reg)
Old Jul 27, 2022 | 05:57 PM
Chris008's Avatar
Question KLX250S overcharging (its not the volt reg)
Hi folks, I'm new to the forum and hoping for a hail Mary pass from someone here to help with a real headscratcher of an electrical challenge.
I picked up a 2015 KLX250S as a non runner (standard bike, EU/UK model), turns out the CPU was fried, changed that and bike is running fine BUT it overcharges to the tune of 17.5 volts.
So far we've tested/replaced:
  • Voltage Regulator - tested with three different new Volt Regs, bike sits with a new Kawa OEM unit at present but still no dice, still over charges
  • Bike had incorrect Stator/Generator fitted, we pulled that and replaced with new Kawa OEM unit, better, stable but still overcharging now at 17.5 volts (with incorrect Stator volts would just keep climbing to 19+ before we cut the engine to save the CPU).
  • New battery, tested and all good and tight at 12.8 to 12.9 volts
  • New earth strap/connections
  • Checked wiring loom, OEM and no signs of hacked wires
All electrical components and systems (lights etc) function correctly.
Has anyone come across this sort of over charging challenge before? Bike is a clean straight machine in good overall condition, full factory new charging system yet still the over charging challenge.
Thanks for reading
Chris008
Jul 28, 2022 03:33 PM
FstaRockr Burns
May 21, 2014 05:34 AM
95451
Sep 19, 2009 10:17 PM
5skin
Mar 17, 2008 01:50 AM
