Klx250s melted piston help?
Old Dec 1, 2011 | 11:51 AM
  #31
Lockie666's Avatar
Originally Posted by neilapples
I think Bill goes away on holiday’s alot, but he will answer you eventually. Just leave an email.
What is his email? there isn't one on his site?
Old Dec 1, 2011 | 02:20 PM
  #32
Blackheart58's Avatar
Try: b_jblue@sbcglobal.net
Old Dec 3, 2011 | 12:37 AM
  #33
MaverickAus's Avatar
Yep just email him and wait for a reply, he will answer you assuming he is home.
Old Dec 23, 2011 | 05:15 AM
  #34
Lockie666's Avatar
Update on my situation, my 351 kit is on a plane to Australia as we speak!
What jets can you suggest I use and should I leave the carby as it is and put it all back together or should I rejet it while it's all apart now?
I've also got all new valves springs collets stem seals and everything for the head I just need to get the valve seats reset and new valves and stuff.
Oh and a suggestion on how many teeth sproket I should be using, I do 50/50 on and offroad. Onroad it's usually on the freeway so I need to be able to sit on 100 110Kmh without revving the *** out of it.
Cheers to everyone for helping me get to where I am now
Old Dec 23, 2011 | 01:25 PM
  #35
On jets, Mr. Blue recommended +1 on pilot and +2 on main. I'm using the stock carb and bumped the pilot from #35 to #35 Kaw jet, and main from #124 to #132 dynojet. I also moved the clip down one on the needle (from 2nd to 3rd notch from the top).
Old Dec 23, 2011 | 02:56 PM
  #36
Ranger Ron's Avatar
For some reason, your down-under main jetting is quite a bit different than the jetting up here, so specific jet size recommendations from the north may not apply.
Usually with a big bore, you don't have to make much of a change with the main jet. The reason for this is that with a larger displacement more air is being drawn into the engine for the same piston speed. This increases the intake velocity. The increased intake velocity adds more fuel automatically.
If I remember correctly, the oem main jet for my 2006 was a 118. With the 351 a 120 main works best for me.
Ron
Old Dec 23, 2011 | 05:17 PM
  #37
Ron:
My oem main Kaw jet was a 118 also. Bill recommends +1 on the pilot and +2 on the main. This recommendation should translate to the down-under folks too, I suppose. Who knows, Bill may be recommending a little on the conservative side to decrease the chances of lean running.
I can agree with your point on more air flow equals higher velocity in the venturi (carb) which decreases pressure in the venture which in turn causes more fuel flow through a jet. A jet operates on the orifice equation, which is a power equation so a given increase in pressure on the jet will result in increased fuel flow, but the relationship is not linear (e.g. 50% pressure increase on the orifice pressure can yield about 24% more flow on one example I just tried). Since the venture is also a power equation, maybe this all works out in a balance where a 25% air flow increase yields about 25% increased fuel flow. I dunno...just rambling thoughts.
Old Dec 27, 2011 | 07:24 PM
  #38
Ranger Ron's Avatar
Originally Posted by IDRIDR
Ron:
I think about these kinds of things, too. I guess we need to get a life.
Ron
Old Dec 27, 2011 | 08:42 PM
  #39
ol'klx-er's Avatar
Ride more! Thimk less!
Old Dec 28, 2011 | 02:45 PM
  #40
Ranger Ron's Avatar
I was also thimking about riding!
Ron
