klx250 sprockets
Old Mar 30, 2012 | 11:52 AM
stephenmarklay's Avatar
Originally Posted by Watt-man
Ha! I'm 6'5" tall and weigh 230 with my gear on! Running 15/39 AND a tall rear tire. It's geared way up there but I like it that way.
Nice, what kind of speed can you maintain on the highway?
Old Mar 30, 2012 | 01:25 PM
Watt-man's Avatar
I don't really look at it as what I can maintain, but what is comfortable to maintain. I'm not a fast rider.
Stock, if left alone on the open road, I find that I ride about 45-50 mph actual (50-55 indicated) and really enjoy the ride. But that's too slow for the freeway so I feel like I'm spinning it uselessly to stay up with traffic.
With the 15/39/tall tire, I find that I'm comfortable at 58-64 mph actual (64-70 indicated). Sixth is now a cruising, 'maintaining speed' gear. If you want to accelerate, 5th gear is only 10% away so you should use it. Or 4th. spin it, get it up to your speed, then go back to 6th.
It hasn't changed what the bike 'can maintain' because you just downshift and choose the gear that is appropriate for the more aggressive riding.
Old Mar 30, 2012 | 02:40 PM
eyyopomps's Avatar
whats you gas mileage like with your setup?
Old Mar 30, 2012 | 03:01 PM
Thanks and the comfortable speed was what I was getting at.
Where is the speedo gear and can it be calibrated to indicate more closely to actual speed?
Old Mar 30, 2012 | 05:35 PM
GaryC's Avatar
$79.00 from HERE: SpeedoDRD
Andyesi stilledit my posts becasue i cant spell fer**** and havefatfingersonthekeyboard
Old Mar 30, 2012 | 05:58 PM
Thank you! A better question is why is it off from the factory?
Old Mar 30, 2012 | 11:41 PM
GaryC's Avatar
That is a good question. from my understanding, the Odometer is correct but the Speedometer is off exponentially (more as you go faster).
???????? dont no
Old Mar 31, 2012 | 02:29 PM
  #28
Watt-man's Avatar
Average of last 9 street tanks: 81 MPG.
Old Mar 31, 2012 | 02:41 PM
  #29
Watt-man's Avatar
Agreed, I was really disappointed. When we had mechanical units, I understand they're not easy to make the odo and speedo present both accurate numbers, but sheesh, on these electronic units, the odo and speedo should be off by the EXACT same percentage.
I was really disappointed with the stock KLX on this front.
The speedometer reported high by a very consistent 10%.
The odometer reported high by a very consistent 4.3%.
The "whys" of this are wide-open to debate so that's not my point of this post but I can see how people would believe they're getting 4.3% higher MPG than they really are (my 81 MPG average posted in the previous post is actual, not "indicated"). And by the same token, people would think the bike is 10% faster than it really is "Hey, I was going 65 mph all day"... no you weren't, you were going 59.
Anyway. I digress.
I ended out using a speedohealer. Works great, but because Kawasaki doesn't have the speedo and odo with the same error, you must decide what's more important to have "accurate", or if you want to split the two errors and have them both off "by less".
For instance:
** If you leave it alone, the speedo is 10% high and the odo is 4.3% high.
** If you make the speedometer accurate, the odo is 5.5% low.
** If you make the odometer accurate, the speedo reports 5.5% high.
** If you split the difference, the odo is 2.8% low, the speedo is 2.8% high.
I chose to make the speedometer accurate because that's the number that I want correct "on the fly" when quickly glancing down at the gauges. When buying gas and entering records, I have the time to use a 1.055 correction factor on the miles traveled to see how far I really traveled.
Hope this helps.
Old Mar 31, 2012 | 05:03 PM
  #30
Anyway. I digress.
For instance:
Hope this helps.
They don't make that Speedohealer as a direct fit for the 2006-08. They have a generic one.
