KLX250 EFI hard to start when warm
Old Aug 17, 2016 | 01:47 PM
mrtee's Avatar
Default KLX250 EFI hard to start when warm
Hi all, I have the KLX250 EFI 2009 european model and it starts fine from cold. However when warm it is tricky, always starts but you have to play with the throttle to get it to start each time. I have checked valve clearances and they are all in spec. Anything else I can check?
Thanks.
Old Aug 17, 2016 | 01:54 PM
peabrain's Avatar
check your auto compression release valve i would look in to disabling it
i did that doing the MCM cam mod starts instant both hot and cold
Old Aug 17, 2016 | 01:57 PM
mrtee's Avatar
Hi, is there a guide for how to disable it? Thanks.
Old Aug 17, 2016 | 01:58 PM
mrtee's Avatar
Forgot to add, did you have the same issue as me?
Old Aug 17, 2016 | 02:26 PM
peabrain's Avatar
mine took 3-4 seconds cranking before start no throttle
Old Aug 17, 2016 | 02:27 PM
peabrain's Avatar
https://docs.google.com/document/d/1...m3gkMeNUU/edit
you can just to the disable part and be good
Old Aug 18, 2016 | 01:27 AM
outrecording's Avatar
I have that very similar problem with my EFI. Never had it until after the big bore mod though. So maybe it's for different reasons. Mine can sit for two weeks in the rain (covered) and start instantly. But let it warm up and then it won't start without some throttle. I've checked compression, valve clearance, played with fuel controller settings...but nothing. Last resort is do what was recommended above, disable KACR and see what happens.
Do report back if you ever figure out what's causing the problem.
Old Aug 18, 2016 | 01:31 AM
Btw, exactly how does yours act when trying to turn it over and it fails? On mine, it will often catch, but only at a very low RPM for about a second. Just not enough to get it to idle and it dies. Giving it throttle will bring that low RPM up enough not to die. Is that similar to what you're experiencing?
Old Aug 18, 2016 | 10:54 AM
peabrain's Avatar
i once had the problem of the battery being a bit low and causing the bike to die after a few seconds
(due to load on stator causing efi system to cut off)
peabrain
May 15, 2016 07:11 PM
Gene Pavlovsky
Nov 8, 2015 05:27 PM
cegusman
Sep 25, 2012 02:08 PM
IQOUTLAW
Mar 23, 2010 02:33 PM
89 Ninja
Oct 19, 2007 07:35 AM
