KLX250 2010 rearshock rebuild,,
Old Mar 20, 2013 | 07:46 AM
Subseageorge's Avatar
Default KLX250 2010 rearshock rebuild,,
Guys,
I am stripping my shock, I have the spring off and was about to take the bladder out, but there is no valve on my bladder resevoir. Is the cap held in with the spring clip just a cover??
I have got the spring clip out but i cannot get the cover off.
There is a small hole in the centre about 3/16" but no schrader valve.
Is this normal? I do not want to go crazy as maybe trapped pressure in the bladder.
Everything i have read says there is a valve here,?? but mines does not have a valve?
Your help is much appreciated.
George
Old Mar 20, 2013 | 01:38 PM
Pogiboy's Avatar
This should help you. Type Yamaha rear shock rebuild on google and select the video part 1 on YouTube . Should work for you .
Old Mar 20, 2013 | 01:43 PM
http://www.facebook.com/settings/?tab=applications#!/photo.php?fbid=10151580131971663&set=pcb.101515801 32061663&type=1&theater[/IMG]
Old Mar 20, 2013 | 01:48 PM
Is there anyway i can post a picture on here??
Pogiboy's Avatar
According to that video you will need an adaptor to screw inside
Old Mar 20, 2013 | 01:50 PM
[IMG]http://www.facebook.com/#!/george.bell.507/posts/10151580132061663
Old Mar 20, 2013 | 01:51 PM
Sorry i cannot open the video,, still trying,,
An adapter to release the gas ,, or to remove the cap?
Thanks
Old Mar 20, 2013 | 01:54 PM
Pogiboy's Avatar
Select the YouTube video part 1 good luck. This should help you.
https://www.google.com/search?q=yama...&client=safari
Old Mar 20, 2013 | 01:56 PM
ok watching it now,, managed to get it to play,,
Old Mar 20, 2013 | 01:58 PM
Pogiboy's Avatar
Good luck. To upload pics use photobucket
