KLX Rear shock rebuild?
Old Oct 9, 2012 | 04:45 PM
Subseageorge's Avatar
Default KLX Rear shock rebuild?
Hi ya all,
Does anyone know if i can rebuild my own rear shock?
Or of anyone in Indonesia or malaysia that will ?
If not where is the best place to buy a replacement?
Thanks
Old Oct 9, 2012 | 06:37 PM
Originally Posted by Subseageorge
Hi ya all,
Thanks
Yes, an individual can rebuild the KYB rear shock on our KLX without too much difficulty. In fact IMO I think it's easier to work on than the front fork...needs less special tools. And if you're just going to rebuild the rear, as in change oil and maybe replace the main seal, it's even easier. And unless you're doing a lot of consistent, gnarly, harsh, off road riding without any breaks where real heat buildup may occur, you don't even need nitrogen in the piggyback bladder. The repair manual walks you through the process quite clearly, so check it out. I didn't buy an special tools at all for the rear shock revalve I did on mine, but look at the manual to see if you have everything you need.
Why do you feel you need a rebuild?...blown seal?...or just time for an oil change? I'd recommend replacing the main seal if you're just needing an oil change, as it's easy to do once it's apart. I'd recommend staying with the KYB seal also.
Old Oct 10, 2012 | 04:57 AM
Brewster's Avatar
What model KLX?
Like TNC said, it's not all that difficult. But, you will need a source of high pressure nitrogen or air, like 150 lb. If you do it, it would be a good time to also try revalving it.
Ride on
Brewster
Old Oct 10, 2012 | 05:40 AM
If you decide to charge the shock bladder with air, you can use a convenient bicycle shock pump. They aren't expensive. There are different models with different gauges that can read all the way up to 300 psi, so they're very capable of servicing the bladder pressure. They also have a valve head that doesn't let air pressure drop in the bladder when you unscrew it. High end mountainbikes in particular have been using these pumps for their forks and shocks for years now, and they work excellently.
Old Oct 12, 2012 | 11:32 AM
Does any one have the Details from the manual as my manual does not tell me how to rebuild it,, just how to repalce it??
The seal is blown,,
Thanks
Old Oct 12, 2012 | 12:08 PM
MaximusPrime's Avatar
Don't worry about the Nitrogen, you're breathing air that is mostly Nitrogen anyway. Go with what TNC said. The bike shock pumps are nice and can be had cheap, you might have one already if you have a nice suspended mtn bike.
I need to re-valve front and rear. Nice to hear it's possible.
Old Oct 13, 2012 | 06:57 AM
Do you know where i can get a copy of the repair manual you are quoting from,??
Thanks
Old Oct 13, 2012 | 04:42 PM
Brewster's Avatar
Thanks
Maybe at the top of this forum where it says: Sticky: KLX Manuals
Ride on
Brewster
Old Oct 19, 2012 | 10:40 AM
Ride on
Brewster
That is where i got my manuals from, They only show how to remove and fit a shock. not dismantle it.
Old Oct 19, 2012 | 11:45 AM
Brewster,
I found it in the 1997 manual but it is not in the later one. Does anyone know if they are all the same, apart from the parts??
Thanks again guys,,
