KLX high/lo beam separate elements or
Old Jun 11, 2013 | 01:40 AM
Richard Avatar's Avatar
Default KLX high/lo beam separate elements or
Does hi beam have both hi and lo coming on together?
I've tried to look when my D Tracker light is on, but it's just blinding.
I don't ride at night usually, so I am thinking about using the hi position on the switch for an Off switch position if I disconnect that line inside the switch or near it..
Old Jun 11, 2013 | 02:54 AM
ol'klx-er's Avatar
It's one or the other. If I switch mine ('09) slowly both will light up "in between" the switch positions.
Old Jun 11, 2013 | 04:42 AM
linkin5's Avatar
Same here if you put my high low switch in the middle both elements will light and it is a little brighter.
Old Jun 11, 2013 | 08:24 AM
Cool..thanks guys
Old Jul 4, 2013 | 02:13 AM
I cut the hi beam wire inside the switch yesterday and can tell that not having that powerful headlight draining power at the same time I am starting it is a big plus.
Using the hi beam position as an Off switch may be low tech, but it was quick and easy and still keeps the on/off choice handy at my left thumb.
LCubanaso
Apr 10, 2014 12:45 AM
deej
Aug 21, 2008 01:47 AM
Whiteman
Apr 11, 2007 07:04 PM
kali_ninja500
Ninja 500R
18
Oct 29, 2006 05:28 AM
Hayate6
Aug 20, 2006 07:05 AM
