KLX fan assembly
Old Apr 17, 2012 | 03:47 PM
amit22's Avatar
Default KLX fan assembly
hello
I have KLX 250D
those bikes (250D) dont come with fan at all.
I bought fan and I dont know where to connect the (+) and (-) wires
here is my wiring diagram:
Photo1678JPG - UpF.co.il
this link to download my wiring diagram...please help me
Old Apr 17, 2012 | 04:02 PM
Ok that was in Hebrew, and so I'm not sure what to do here.
Old Apr 17, 2012 | 04:03 PM
Oh and welcome to the forums.
Old Apr 17, 2012 | 04:30 PM
amit22's Avatar
LOL I totaly forgot !
just click the "הכן קובץ להורדה"
that is blue frame
thanks!
Old Apr 17, 2012 | 04:32 PM
amit22's Avatar
and then click the
"הורד את הקובץ עכשיו"
that is another blue frame
Old Apr 17, 2012 | 04:36 PM
I still got nothing, and now its asking me to download something, sorry can't do that.
Old Apr 17, 2012 | 05:11 PM
amit22's Avatar
Old Apr 17, 2012 | 05:12 PM
LikesToThump's Avatar
Either way... if your bike doesn't have a fan, will it still have the thermistor/thermocouple along with the relays to actuate the on/off current for the fan?
If not a fan is pretty useless...
Old Apr 17, 2012 | 05:27 PM
amit22's Avatar
no I dont have the sensors and relays...
i just want to connect it directly to voltage source of 12V through on\off switch
but I just can't find the 12v wire...
I can't take voltage from the CDI unit (that kind of thing wants to turn off the bike)
my only option is from the yellow wire that goes to the regulator, and it gives my only 3V .
is it normal ?? maybe my stator is weak??
Old Apr 17, 2012 | 05:36 PM
Remove the seat, look towards the back and locate the little fuse box (has like only 3 fuses)... splice into the heavy gauge wire going into the fuse for the headlights. Make sure the splice is BEFORE the fuse and on the proper terminal side so you are not drawing current through the fuse for the headlight. Install an inline fuse with you splice for safety... this is your + it will go "hot" only when the key is turned on now. Negative - naturally is ground... ground it wherever your little heart pleases. Now you will be able to wrap tape around the inline fuse and the fuse box with electrical tape and have a neat and presentable look for you new "fuse box".
Use zip ties, heat shrink, crimps as needed.
