KLX as an adventure tourer? '06-07' vs +'09?
Old Jan 23, 2016 | 12:04 PM
It is all about creature comforts, even a 50cc bike can do the work - run down the road - from there it is what you want. Some want everything - BMW GS, others will sacrifice some - KLR650 - and you are willing to give up the extra power for get rid of a lot of weight. Sounds like you know what you're giving up and are okay with it.
One thought - spend the money to get the suspension revalved/resprung to suit your weight and added bike weight as well as getting a significantly more plush ride. I'd think a well set up 250 would work pretty well in the comfort area. But if you stack up a bunch of luggage and yourself on the stock set up you're going to have it wallowing and bottoming out a lot.
Oh, and I'd go with the 3.7 tank one way or another. A bit extra gas never hurts.
Old Jan 23, 2016 | 12:10 PM
griffo1962's Avatar
Thumbs up
I've made my '12 into a nice little ADV bike. Built my own racks, fitted the Acerbis tank as well as a SC seat. I also use a sheepskin & Airhawk (for extra leg room)
Old Jan 23, 2016 | 01:38 PM
stewacide's Avatar
BTW, the Acerbis tank will fit the newer model, it just has an ugly gap between seat and tank.
I wonder if fitting an earlier model seat wouldn't be an option to fix that? (not that it's a big deal).
Old Jan 23, 2016 | 01:42 PM
MaximusPrime's Avatar
I've thought about that, but it would require side plastic too and not sure that those would fit...
Old Jan 23, 2016 | 01:49 PM
stewacide's Avatar
This is the sort of setup I have in mind. Although I was thinking soft bags. What cases are those? Made yourself?
I won't be under any time constraint, and I always go slow (to soak it in) when traveling, so not worried about long highway runs.
Old Jan 23, 2016 | 02:15 PM
stewacide - you can see the tank/seat gap on Griffo's bike
Old Jan 23, 2016 | 07:36 PM
griffo1962's Avatar
yes, made myself from 20L fuel drums. I had to pay someone to weld the aluminium for the lids.
Old Jan 31, 2016 | 12:55 AM
tysonb's Avatar
Griffo1962,
Can you provide some details on that windshield please?
Old Jan 31, 2016 | 11:04 AM
griffo1962's Avatar
Originally Posted by tysonb
Griffo1962,
it's off a Triumph XC. Made a couple of bent brackets from top of forks & drilled a small hole in the centre at the front. I plastic welded a small nut behind the mask to bolt it to.
JaMan
Sep 10, 2013 10:15 PM
cjc
Jun 15, 2011 08:18 PM
durden
Jul 26, 2010 03:12 PM
Marty
Jul 6, 2006 01:08 AM
motoguy128
Mar 15, 2006 02:08 AM
