KLX 250 Starting Problems
Old May 4, 2012 | 10:40 PM
  #41
MyKlx's Avatar
Default Hard Starting
Hi All,
My KLX is starting good now.
I found that the Starter Jet was plugged solid. I drilled it out to 0.0180" and it starts right up with the choke on of course.
A special thanks to "TNC" for the help.
Safe and good riding to all,
Roy
Old Mar 21, 2014 | 01:54 AM
  #42
Frampton's Avatar
if anyone is still watching this would it be advised to drill out my starter jet more then 0.018" if i have the problem and a 351 kit? i would think the 350 would need a bigger choke then a 250 right?
Old Mar 21, 2014 | 02:14 AM
  #43
I would stick with the .018. I have mine drilled and run the 351, works fine.
Old Mar 21, 2014 | 02:31 AM
  #44
Frampton's Avatar
thanks! i see you also have a 40 pilot too tho. wouldnt this also give more gas for startup?, i have had a 35 and only just bought a 38, havent put it in yet though
Old Mar 21, 2014 | 03:12 AM
  #45
linkin5's Avatar
I had an old Honda xl600 kick start only and it was cold natured as heck, turn on the gas lay it on it's side for 15-20 seconds and it would fire up even in cold weather. It caused it to flood just a little bit and that was all it needed.
Old Mar 21, 2014 | 09:22 AM
  #46
Amplegirthage's Avatar
Default Finally cured my cold start problem
Well I went through all the cold start threads last year when I first got my KLX and thought I had it licked by upping the float level. But it didn't last long before I was back to draining the carb bowl after the bike had stood for a while.
The bike was popping on the overrun, so to cure this I increased the pilot jet from 35 to 38 this cured my exhaust popping and as if by magic IT STARTS EVERYTIME hot or stone cold or after a weeks layup.
I haven't drilled the starter jet.
Old Mar 21, 2014 | 05:20 PM
  #47
RaceGass's Avatar
With a 40 pilot I had the fuel air screw out 1.25-1.5 turns out. This is at sea level. Starting wasn't a problem even without drilling the starter jet. Only ran premium 91 octane, 2 gallon tank only .40 cents more.
Never did the grounding procedure either and no surging ever.
Old Apr 19, 2014 | 03:01 PM
  #48
tracya's Avatar
My KLX is starting better than it ever has... Thanks TNC for the posts!
Websurfing101
Aug 12, 2015 01:28 AM
lenotonight
Sep 15, 2007 02:15 AM
remster
Jan 2, 2007 06:52 AM
Joe00zx
Oct 26, 2006 08:57 PM
schnebelen
Jul 6, 2006 05:38 AM
