KLR650/KLX300 Wheels
Does anyone know if the frontwheel off a KLR 650 or a KLX 300 will fit on our bike?
I see small differences on the make up of the hub, but overall they are similar.
ORIGINAL: Divodave
2006 KLX300 front hub p/n 41034-1219 fits the following
· KDX200-E5 KDX200 (1993)-->FRONT HUB (KDX200-E5/E6)
· KDX200-E6 KDX200 (1994)-->FRONT HUB (KDX200-E5/E6)
· KDX250-D2 KDX250 (1992)-->FRONT HUB@ (KDX250-D2/D3/D4)
· KDX250-D3 KDX250 (1993)-->FRONT HUB@ (KDX250-D2/D3/D4)
· KDX250-D4 KDX250 (1994)-->FRONT HUB@ (KDX250-D2/D3/D4)
· KLX250-D2 KLX250R (1994)-->FRONT HUB
· KLX250-D3 KLX250R (1995)-->FRONT HUB
· KLX250-D4 KLX250R (1996)-->FRONT HUB
· KLX300-A10 KLX300R (2005)-->FRONT HUB
· KLX300-A2 KLX300R (1997)-->FRONT HUB
· KLX300-A3 KLX300R (1998)-->FRONT HUB
· KLX300-A4 KLX300R (1999)-->FRONT HUB
· KLX300-A5 KLX300R (2000)-->FRONT HUB
· KLX300-A6 KLX300R (2001)-->FRONT HUB
· KLX300-A7 KLX300R (2002)-->FRONT HUB
· KLX300-A8 KLX300R (2003)-->FRONT HUB
· KLX300-A9 KLX300R (2004)-->FRONT HUB
· KLX300A6F KLX300R (2006)-->FRONT HUB
· KLX300A7F KLX300R (2007)-->FRONT HUB
· KLX650-A1 KLX650R (1993)-->FRONT HUB
· KLX650-A2 KLX650R (1994)-->FRONT HUB
· KLX650-A3 KLX650R (1995)-->FRONT HUB
· KLX650-D1 KLX650R (1996)-->FRONT HUB
2006 KLR650 front hub p/n 41034-1153 fits the following
· KL650-A1 KLR650 (1987)-->FRONT HUB
· KL650-A10 KLR650 (1996)-->FRONT HUB
· KL650-A11 KLR650 (1997)-->FRONT HUB
· KL650-A12 KLR650 (1998)-->FRONT HUB
· KL650-A13 KLR650 (1999)-->FRONT HUB
· KL650-A14 KLR650 (2000)-->FRONT HUB
· KL650-A15 KLR650 (2001)-->FRONT HUB
· KL650-A16 KLR650 (2002)-->FRONT HUB
· KL650-A17 KLR650 (2003)-->FRONT HUB
· KL650-A18 KLR650 (2004)-->FRONT HUB
· KL650-A19 KLR650 (2005)-->FRONT HUB
· KL650-A2 KLR650 (1988)-->FRONT HUB
· KL650-A3 KLR650 (1989)-->FRONT HUB
· KL650-A4 KLR650 (1990)-->FRONT HUB
· KL650-A5 KLR650 (1991)-->FRONT HUB
· KL650-A6 KLR650 (1992)-->FRONT HUB
· KL650-A7 KLR650 (1993)-->FRONT HUB
· KL650-A8 KLR650 (1994)-->FRONT HUB
· KL650-A9 KLR650 (1995)-->FRONT HUB
· KL650-B2 Tengai (1990)-->FRONT HUB
· KL650-B3 Tengai (1991)-->FRONT HUB
· KL650A6F KLR650 (2006)-->FRONT HUB
· KL650A7F KLR650 (2007)-->FRONT HUB
2006 KLX250S front hub p/n 41034-1243 fits the following
· KLX250H6F KLX250S (2006)-->FRONT HUB
· KLX250H7F KLX250S (2007)-->FRONT HUB
Sounds like your outta luck, I know the rear KLX300 hub is the same as the KLX250S and most other Kawasaki dirt models.
http://www.kawasaki.com/DefaultFrame...OSEVEHICLE.ASP
click on the top "continue"
click on KLX250S or whatever model you want
click on continue
click on the year model
click on "view" parts diagram
in the right column click on the part you want
click on the part number in the new window that comes up
copy or remember the part number
go back to the original window
click on parts (near the top)
click on "begins with" button
paste or type the part number into the part number box
click search
sounds like a lot but once you have done it a couple of times its easy
cheers
[8D]
click on continue
click search
cheers
[8D]
cpr1
May 30, 2011 04:44 PM
, where/how do you research that info? IfI knew where, Iwould not have to bother people so much.[sm=pcwhack.gif]
