kickstarter help!!!!!
Old Mar 5, 2009 | 12:16 AM
Senator24's Avatar
Default kickstarter help!!!!!
Hi,
I just replaced my idler gear as well as the kick starter gear. I have put it all back together as the factory manual says, but my kick starter does not spring back! Doesn't really say anywhere to tension the spring but simply install. Can anyone help. My ride is a 2000 KLX300. Thanks
Old Mar 5, 2009 | 01:30 AM
lcpl0331's Avatar
Here's one from Finger.
https://www.kawasakiforums.com/forum...kstart+install
There is another install post that talks about exactly what your dealing with but I couldn't find it.
Old Mar 5, 2009 | 01:45 AM
lol....that's it
pull out the kickstart assembly.
1 Now start to slide it back in and stick the spring into the case.
2 Now rotate the shaft to create tension in the spring .... about a 3/4 turn was good for me
3 shove the assembly all the way in.
4 Have a beer you deserve it
Edit Just a note .... I may have spun the spring to create tension and shoved in the kicker and spring together .... can't remember which.....but it was clear which way to do it ... when ya got it in front of ya.
Oh ..... if the kickstarter goes "click...click....click etc" when you start the bike and move the kicker you did not put in enough tension.....you got it...I did the same thing....but noone to ask for help.
Old Mar 5, 2009 | 02:59 AM
Senator24's Avatar
Thanks guys for your help. Worked a treat! Why wouldn't that be in the manual??? Anyway thanks again
t20sl
KDX220R
Mar 1, 2020 02:38 PM
Finger Mullet
Aug 26, 2010 03:53 AM
Finger Mullet
Dec 21, 2007 03:59 AM
JB1
Jan 10, 2007 06:05 AM
crash
Feb 25, 2006 05:24 PM
