kickstand switch bypass location(s)
The other day my wife messed up for the first time by having the kickstand down and taking off. She heard the noise and stopped after she quickly realized her mistake. I told her that I thought it was supposed to kill the engine if that happened and also know many people bypass the switch for engine cutting out annoyances. I looked into it today and the switch tests good and the 2 connectors under the seat are plugged in properly. So, where is another common alternate location to bypass this safety device?
Thanks,
db
edit: spelling [:@]
Thanks,
db
edit: spelling [:@]
ORIGINAL: hoedogg
dang bro she's lucky that the KS did'nt dig in and throw her off[&:]sorry im no techy.
. She was practicing the test course for the motorcycle endorsement and when we were leaving I looked in my rear view mirror and she was stopped so I waitied for her. She said when she took off she heard a loud grinding noise
that she never heard before. Anyway, she took the test last week and aced it.
db
My KLX is bone stock and My kickstand can be down while riding. I never tested the switch but Something is wrong somewhere. I figured it's ok since lot's of people just bypass it anyway.
ORIGINAL: deej
She passed? That's awesome man. I wonder how many couples on here ride bikes together? Cool.
Yep! She aced the test. Zero mistakes. Can't say the same for the other guy with the HD. The episode with the kickstand was on the practice course we set up on a new subdivision a mile from the house and happened a few weeks before the test. We printed the test course from somewhere we found it online and we set it up exactly with a tape measure and chalk. We cut tennis ***** in half for the cones. I made her practice but it got to where she wanted to practice. I am glad its done.
I wonder how many other couple ride too. She is my wingman
db
ORIGINAL: gerrynolan
We bought it used so although I doubt the last owner modded it, you never know. He was a doctor reliving a chilhood fantasy.db
ORIGINAL: Nobrakes
Check the clutch switch.
, I did check the clutch switch and its working. I looked at the repair manual wiring schematics and I am willing to bet the "diode assembly" will end up being the culprit. I will check it with a VOM when I pull the seat again when I feel like messing with it...Here is the info on tha part:49018 DIODE
49018-1052
I will report back in the future when I test it.
Thanks,
db
Most commonly when a diode is bad , it's bad...if this is an ittermittent problem, be sure to check the connections to the diode. just my 2 cents...good luck
