kenda 761
Old Mar 14, 2016 | 09:09 PM
MJG's Avatar
MJG
Default kenda 761
putting some 761 on 09 250 S
going to be used for light street riding mostly
it has tubes in tires
what air pressure you guys using for daily street riding
Old Mar 14, 2016 | 10:31 PM
I run 32 psi on the road. I got my bike with the 761s, but went to a Duro Median set due to past experience and more off roading. I run 32 psi in them on the road.
Old Mar 15, 2016 | 04:10 AM
durielk's Avatar
Post up if you find them out of round.
Old Mar 15, 2016 | 12:09 PM
I had that tire on my KLR650 and hated it. They were almost slippery. Went back to the 270s.
Old Mar 15, 2016 | 03:55 PM
Werloc's Avatar
I had the 270's on my Yamaha. Man, did they stick on the road. Very good grip on the street for a knobbie tire.
Old Mar 16, 2016 | 04:46 PM
azdeuce's Avatar
32 psi sounds high...
I run 25 rear 22 front and I feel the road.. I'm running Perelli Scorpions
Old Mar 16, 2016 | 08:51 PM
It has proven pretty much perfect on the 650 when chasing my friends around on their supermotos or sportbikes. It is a road pressure, not too good for off road. There I'm around 18-20. Run the same in the 250.
Seems most street bike pressure when it comes to performance riding will range from around 32-35 psi from what I've read, ridden, and observed. The lower pressures are usually more for the cush and comfort, although I do see some of the supermoto riders drop into the mid to high 20s.
I'll stick with the 32 psi when road riding, because of about 30,000 miles of experience with the grip on the KLX650... fast enough in the corners to always be "appointed" the leader. It also earned the KLX the nick name "Hawk killer" after a Superhawk riding buddy kinda did a slow cruise off the edge of the road chasing me on SR60 in Ohio. They had to keep pressing me - so I picked it up a bit...
Old Mar 17, 2016 | 12:43 AM
durielk's Avatar
You outdrove a 305 SH on a KLR? Surprising!
Old Mar 18, 2016 | 12:25 AM
No, A VTR1000F with a KLX650C!
One of these, stock
With this
Before I went to the big bore and pipe, with those kind of tires.
I guess you could say I can ride it fairly well...
Old Mar 18, 2016 | 03:11 AM
durielk's Avatar
Now that is CrAzY!!!!!
I would think the 305 & the KLR would be a pretty good match, but a 1000?????? OMG
