K&N Filter
Old Mar 6, 2008 | 02:55 PM
Default K&N Filter
Hey guys, I did a couple of searches in our section and it didn't come up with anything, although I know there have been posts about the K&N Filter that fits our bike. Does anyone have a part number directly to a K&N that fits our bike exactly? Thanks in advance.
Old Mar 6, 2008 | 03:06 PM
Default RE: K&N Filter
I think I found it on the K&N site.
Old Mar 6, 2008 | 03:09 PM
Is this it?
KA-1287 Product Specifications
Product Style: Tapered Conical Air Filter
Base Inside Diameter: 5.313 in (135 mm)
Base Outside Diameter: 6.5 in (165 mm)
Height: 2.75 in (70 mm)
Inner Wire: No
Top Outside Diameter: 4.75 in (121 mm)
Top Style: Open
Top Material/Finish: None
Filter Re-Oiling Amount: 0.53 oz (16 ml)
Top Inside Diameter: 3.625 in (92 mm)
Old Mar 6, 2008 | 03:54 PM
ol guy's Avatar
That looks like the correct number. It's a bit of a chore to get the filter in the air box but it does go in. I've beenusing k&ns in my bikes since the early 80's, no complaints.
Old Mar 6, 2008 | 04:58 PM
Dats the one, been on my bike for almost two years now, no problems.
Old Mar 6, 2008 | 05:14 PM
finger dont you worry about the sand with a k & n.... i herd in dusty conditions foam filters were better.
Old Mar 6, 2008 | 06:49 PM
ol guy's Avatar
I've been riding in the sand and dust as long as i have used k&n filters. I also use them on my truck. No problems. A little grease on the sealing faces insures a good seal. If you want to check the effectivness of the filter just run your finger around the inside of the boot running to the carb. I have lots of miles riding in a dirt cloud, (mostly because the guys I ride with are faster) and the K&n is great.
Old Mar 6, 2008 | 09:29 PM
chris72a's Avatar
So silly question, do you still need to oil the K&N
Chris.
Old Mar 6, 2008 | 10:11 PM
KLXer's Avatar
They stil need to be oiled.
Old Mar 7, 2008 | 12:04 AM
ORIGINAL: EMS_0525
Nope not at all....K&N's are just fine, just like ole guy said....sometimes when really dusty, I putmy pre-cut piece of k&n prefilter fabric over the open airbox, but not often.... and that's just to make the k&n main last longer.. before cleaning.
I usually worry most about water gettinin on water sections...lol
