k&n #
Old Jul 21, 2006 | 04:51 AM
blacktail's Avatar
Default k&n #
Is this the right Part number kn1287 kn web site says it fits kdx200 klx300r dose not show klx300?
Old Jul 21, 2006 | 05:42 AM
krntl13's Avatar
Default RE: k&n #
I believe that is correct but I saw it posted as KA1287 but may be the same
Old Jul 23, 2006 | 06:30 AM
gfoster's Avatar
Default RE: k&n #
KA-1287, took it right off the box, and I have one on my bike.
Old Jul 23, 2006 | 06:48 AM
Default RE: k&n #
How do you like it, gfoster? I've had one on back-order for over a month now. Where'd you get yours?
Old Jul 23, 2006 | 08:56 PM
gfoster's Avatar
Default RE: k&n #
My bike is stock right now because my Muzzy is backordered, however, the K and N really made a difference climbing at higher altitudes in the mountains. The bike would not pull itself up the trail at around 8,500 feet in NM until I removed the top off the airbox and installed the K and N. As long as you keep the RPM's around 6000, it will climb no problem, the problem is when you have to let off the throttle to navigate a switchback and then start up a steep grade. I have ordered a lot of parts lately but I believe I ordered it from http://dirtbikediscount.com/index.cfm.
Some people believe the K and N does not filter as well as a foam filter, I have read many articles on the subject and have come to the conclusion that it is as good as any and I hate servicing foam filters.
I use the K and N on both my bikes, car, and truck. You might check into a UNI, which is foam and is supposed to have better air flow than the stock filter.
Old Jul 24, 2006 | 12:38 PM
MaverickAus's Avatar
Default RE: k&n #
Only problem is you did 2 things at once remove the air box lid and installed the K&N, so your results are not valid. Not being nasty just saying facts. If you had done 1 mod at a time your results would be more useful. I am glad for you that you like it
