IMS tank w/'95 shrouds
Well I finally got all the parts for my project to install a new IMS tank and 1995 KLX shrouds.
Waitingforparts.jpg?t=1236395073
Waiting for parts
After pulling all the wiring out toward the front, removing the welded wire brackets, removing the fan, and moving the spark plug coil up 1/2", the tank was mounted.
Tankonframe.jpg?t=1236396866
It is definitely a tight fit. Less than 1/2" to the radiator
I originally ordered two 800mm fans to mount, but the right side didn't have enough room so I had to order a 700mm fan.
700mmFan.jpg?t=1236397575
I ordered push ties to mount the fans through the radiator fins, and they worked pretty well. However, I did tear a fin because I pushed the tie to fast. Didn' seem to hurt anything. No leaks.
800mmFan.jpg?t=1236397853
I had to add about 8" of wiring to get the fan relay back on it's mount.
FanRelay.jpg?t=1236398024
I also had to elogate my seat mounts to get the bolts to fit.
ModifySeat.jpg?t=1236398171
I found this flange bolt in my tool box and it fit the seat perfectly. I did grind down the top a little to make it easier to slide the seat on and off.
SeatMount.jpg?t=1236398391
Then I mounted some rad guards to protect all my hard work.
Unabikerguard.jpg?t=1236398540
And the final touch. The new shrouds:
ShroudLeft.jpg?t=1236398656
Shroudright.jpg?t=1236398728
Shroudfront.jpg?t=1236398798
Shroudforward.jpg?t=1236398868
1995Srouds3.jpg?t=1236398948
Just need this weather to warm up and I'm gone.
Waiting for parts
Very nice, DS! Like Magoo said in another thread, though, you might want to put a little cushioning between the radiator and the fan so that it doesn't wear through with vibration - it's just thin aluminum back there. It's been a while since i did mine, but I think I used a bead of black RTV sealant. The foam tape that Magoo suggested might be even better.
Finger Mullet
Mar 29, 2008 02:50 PM
