Ideas on lowering KLX
Old Jul 23, 2010 | 11:21 AM
09klx's Avatar
Default Ideas on lowering KLX
What do you guys think about lowering the KLX ride height?
-Any problems with lowering it an inch or two?
Old Jul 23, 2010 | 12:22 PM
zomby woof's Avatar
https://www.kawasakiforums.com/forum...lowering+links
Read through.
Most people still don't understand how they work, or what they do.
Old Jul 23, 2010 | 03:51 PM
jckid's Avatar
I put 1" lowering links on mine and raised the front forks as much as I could without hitting the handlebars (about 3/4"). It did soften the rear a little, so I put a little bit more preload on the rear spring. I cannot notice any difference in handling from stock. Works great. If you lower any more than that, you'll need to shorten your kickstand.
Old Jul 23, 2010 | 05:37 PM
FlyingFinn's Avatar
Adding preload does not make the spring harder.
Preload is almost like a ride height adjuster, not spring rate adjuster.
Mikko
Old Jul 23, 2010 | 06:53 PM
GreenMonsta's Avatar
Type in klx250s lowering on Ebay someone is selling threaded adjustable links. I want a set so I can fine tune ride height, I don't want to buy a pre set link and get stuck at some weird ride height when I can spend 30$ more and be comfy.
Old Jul 24, 2010 | 12:38 PM
eeore39648's Avatar
Make sure the spring tension is set correctly for your ride weight.
My bike was setup for a much heavier rider. It was tall and intimidating. After setting it for my ride weight, no lowering was needed.
JMOP
Old Jul 24, 2010 | 03:41 PM
Try leaving it alone for a year. You'll probably get used to it. You won't loose your clearance or the factory geometry. I'm 5'7" and my bike is a little tall for me but I really don't notice it anymore.
Dan
Old Jul 24, 2010 | 04:30 PM
gtf's Avatar
gtf
I'm 5'6". I chose to shave a little off the foam off the seat rather than tweaking the factory geometry of the suspension.
Old Jul 24, 2010 | 07:31 PM
Dan
Exactly, the klx is already a low seat height 'girls' bike. At first the klx seemed a little high but I got used to it, 30" inseam, now my klx has raising links and a guts racing High Seat.....shoot my ktm640 adv is up at 37".
Go ride in dirt and get used to it.
Old Jul 24, 2010 | 08:14 PM
LOL!...no kidding on the stock height. I've had skyscraper tall dirt bikes for a long time and just came from a KLR650 with suspension mods that raised it even further. The KLR is stupid tall just like lots of real dirt bikes...no, the KLR is not a real dirt bike. With 11" of travel, I thought the KLX250 would be like other bikes I'd ridden...tall, tip-toe height. I'm 6' tall but have the long torso/shorter leg build of real men. I was shocked to find how how flat footed I can sit on the saddle of this bike. I even have stiffer front and rear springs. I love the setup on this bike, but F. Mullet...I hate that you referred to it as a girls bike.
