I rejetted
Old Apr 13, 2008 | 04:35 PM
KLXer's Avatar
Default RE: I rejetted
Make sure the spacers areon toplike Dave said,not between the needle & slide. Did you enlarge the slide hole with the included bit?
Sounds like you have the same setup as Dave. What elevation? Depending on the elevation & your Q4 you may to move the clip on the needle up position to the 3rd groove from top & try that (to lean it out a bit).
Old Apr 13, 2008 | 05:04 PM
Flood_33's Avatar
I live around 3100' , cant remember where i put my spacers, however i did take it back out and adjust my fuel screw , to 2 turns instead of 2.5, seems to have help it out quite a bit. If i remember right i slid my spacers on the needle longways, i did not set them on top of the clip. Yes i did drill my slide hole with the bit provided.I'm getting pretty quickat taking my carb out and putting it back in
Old Apr 13, 2008 | 05:28 PM
Davebert's Avatar
ORIGINAL: Flood_33
Yeah, make sure the spacers are on top of the clip. Don't know if these are the same instructions but here is a pdf of the DJ kit I used.
http://www.dynojet.com/pdf/2206.pdf
The carb isn't too bad to remove, but installing takes a few extra minutes. Make sure the boots are line up in the keyed rubber slots too.
db
Old Apr 13, 2008 | 05:32 PM
Flood_33's Avatar
Would spacer placement, make that big of a diffrence?
Old Apr 13, 2008 | 06:33 PM
KLXer's Avatar
YES It is your problem. The spacers are raising your needle to high & making you too rich. Take the slide out & put them on TOP of the clip. It will be better--then set your screw back to 2.5 to re-establish a baseline. The DJ instructions are clear they go on top.
Old Apr 13, 2008 | 10:50 PM
Flood_33's Avatar
Tonite i rip the carb back out to swap spacers....i should pay more attention to details, ah well live and learn. Wonder what it will feel like done right [:@]
Old Apr 14, 2008 | 01:53 AM
KLXer's Avatar
Perhaps you can remove the top without taking the carb off? Or just rotate it, remove top, adjust screw, & put it back? No need to remove the bowl this time.
Old Apr 14, 2008 | 02:02 AM
Flood_33's Avatar
True slide is on top, just lining , the needle back up be a beast. Good idea worth a try regardless.
Old Apr 15, 2008 | 04:26 PM
Davebert's Avatar
ORIGINAL: Flood_33
Well, did you get er back together and its running better??
db
Old Apr 16, 2008 | 12:12 AM
Flood_33's Avatar
Yes i , turned spacers around and moved clip to 3rd spot instead of 4th, took airbox lid all the way off, since i live at 3100 feet and depending on where i ride at i'm either right at or below 3000 feet... kinda a weird setup as of which jet to use , i stuck with the 132 instead of the 128, it still lacks ***** on the lower rpm (2k -3.5k) but once it hits 4k rpm it wheelies...since it is a street legal dirtbike , its gonna lack lower end ***** of say a 250 4 stroke off roader. But overall i am pleased with the performance gains, and i really appreciate all the advice and help you folks have given me. Regards
