I need help trouble shooting 95' KLX250R
Old Aug 19, 2013 | 09:12 PM
chad2787's Avatar
Question I need help trouble shooting 95' KLX250R
I am helping a friend keep his modified KLX250R running and I don't have Valve clearance specs for it.
I have service manuals that go back to 1999 but not to 1995.
His KLX was performance modified by Stroker to a 340cc.
issues are tempermental starting issues won't kick over then out of the blue fires right up on next kick, loading up while cruising bogging down as if getting too much fuel then clears out after getting on the throttle, then popping like a 2 stroke. it has a flat slide pumper carb, and an after market cold start valve the runs a vacume line from intake manifold on cylinder head to air box.
Also has hot start (decompression release lever) on Handle bar.
I will be pulling the carb and doing a complete clean and inspection on it.
Any one have a 95' manual? If so can you shoot me the Valve clearance for IN and EX?
MotoGuy
KLR250
Aug 30, 2013 10:51 PM
fgk228
Jun 11, 2009 01:06 AM
smokey
Jul 15, 2007 12:52 AM
sinfulsanity
800, 800 Classic & 800 Drifter
Jul 30, 2006 11:54 PM
Funkdock
May 29, 2006 09:07 AM
