I don't know what I'm going to do with this.
Old Mar 6, 2011 | 05:00 PM
Feral Donkey's Avatar
Default I don't know what I'm going to do with this.
I had a moment of impulse buying yesterday.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Look at the pics of the bore. Does that look like dirt or a messed up bore? I guess I'll have to wait and see.
Old Mar 6, 2011 | 05:14 PM
Punkinhead's Avatar
Looks like very light surface rust that disappear when you run a hone through it.
Old Mar 6, 2011 | 05:15 PM
lcpl0331's Avatar
Looks like rust. Once you get it take a scotch brite pad to it to see how it cleans up. You may have to get it honed.
Old Mar 6, 2011 | 05:20 PM
zomby woof's Avatar
Give it to me, I'l look after it for you
It'll probably clean right up.
Old Mar 6, 2011 | 05:52 PM
ol'klx-er's Avatar
If it's really messed up they say they'll make it good. A bit of light surface rust and some sort of bit of lint in the photo. DO NOT PANIC ............................. YET.
Old Mar 6, 2011 | 06:56 PM
+1 looks OK from the pic very light rust. No piston though?
Old Mar 6, 2011 | 07:54 PM
Nope, no piston. I tell you what though. If the 300 piston is like the 250 piston, I'd rather have the forged Wiseco piston and rings anyway. Can you hone the Nikasil? I honed the sleeve in my 80mm jug. That sleeve material is some tough stuff! I have a friend with an '09 250s and a friend with a '06 250s. I'll see if they want it. If the nikasil is narfed up, it'll be used as a core for a big bore project.
Old Mar 6, 2011 | 08:14 PM
David R's Avatar
I don't know how the nickle aluminum coating can rust. Looks smooth, can't really tell till you hit it with a hone (a little) and measure for out of round and taper.
David
Old Mar 6, 2011 | 08:17 PM
maninthesea's Avatar
Listing is closed so I could not see but from reading the comments it sounds like you picked up a bored out nikasil plated cyl. My experiance was the nikasil is tough stuff but my 330cly must have had a thin wall becuase it cracked. I am now a fan of the sleaved cyl's
If you picked up a 330cyl contact bill blue. he has my old 330 piston and said it was in excelent condition.
Cheers Jim
Old Mar 6, 2011 | 11:19 PM
The rust looks minor and as everyone else said such should clean right up. But in the lower right, is that a pretty good sized gouge?
Worst case, send it off to have it sleeved to 351.
